Previous in Forum: Permanent Magnet Torque Motor   Next in Forum: Hardening
Bearing
05/14/2011 3:15 PM
i have a vertical steel rod which is under compression. It has a load only in vertical direction( Two force member) . It should be connected to plates from bottom and top. What type of bearing should be used? i m considering thrust ball bearing.Any suggestions?
Re: Bearing
05/14/2011 5:03 PM
I'm not sure you need a bearing, at least, not an anti-friction bearing. Do you expect the rod to move?
Re: Bearing
05/15/2011 2:27 AM
no it should not move
Re: Bearing
05/15/2011 10:02 AM
Why do you think you need a bearing, if nothing moves?
Re: Bearing
05/15/2011 10:18 AM
I shouldn't speculate, but maybe he thinks he needs (and he is probably right) something that I would call a bearing plate, to spread the load out so it is not a "point" load.
Re: Bearing
05/15/2011 6:42 AM
Sketch please?
Re: Bearing
05/15/2011 11:22 AM
...............and the known forces that are involved to decided the type of thrust bearing required, etc.
Re: Bearing
05/16/2011 7:56 AM
How about military bearing? or perhaps child bearing? maybe just like me; hardly bearing up?
Andy Germany (1); cenderos (1); JIMRAT (1); lyn (1); MOBI (1); rhkramer (2)
