Previous in Forum: Preflash Tower of Crude Unit   Next in Forum: Static and Rotating Equipment
Elongation Percentage
05/16/2011 5:06 AM
Hi ,
Can any one tell me what is meant by Elongation at break is 12%.
In selection of materials they have given as Elongation percentage.what is meant by that?how can i use this in my design work and material selection process?
Thanks
Re: Elongation %
05/16/2011 5:32 AM
Surely it means 'it got longer by 12% jsut before it broke'
So if it was 100mm to start with, then at at break it was 112mm...
I mean it's not my field, but it seems pretty obious to me.
Dunno how you use it in a 'design calculation' whatever one of those is .
Good Answers: 137
Re: Elongation %
05/16/2011 7:07 AM
Agree with first part.
I don't think you would use it in a design calculation, at least not directly. Unless it's something pretty unusual, it wouldn't be designed to break. OP come back if it is. Normally the important thing is the design allowable stress (much lower than breaking stress, whatever the elongation).
Elongation gives an idea of material toughness, 12% sounds about right for a metal like steel. By contrast, a glass rod would break at much smaller elongation. If selecting a material from scratch you might consider elongation, but usually you have a pretty good idea up front what to make something out of.
Cheers..........Codey
Good Answers: 266
Re: Elongation %
05/16/2011 7:57 AM
In some designs you may want something to elongate before failure. This elongation can be tested for so that it can be replaced before complete failure.
Simple example is head bolts on engine. Torque down the bolts under a lot of stress. Heating and cooling of engine adds more. The mechanic needs to decide when it's necessary to replace the bolts during a repair. He can take the measurements but he is not an engineer. So the engineers need to set some limit and how to test for it.
Codemaster (1); ozzb (1); user-deleted-1105 (1)
