Previous in Forum: If DCS Fails What to Do   Next in Forum: Rob Roy System
10 comments
Aluminium Door Frame Profiles Extrusion Factory
05/17/2011 9:51 AM
ESTABLISHING A FACTORY: ALUMINIUM PROFILES (DOOR AND WINDOW FRAMES).
Hi,
I am looking for the details of establishing a factory for various profiles used in door and windows. I need to know about the machinery needed, and the process details of converting raw material (aluminium sheets etc) to finished profiles.
I am more interested in having practical information on this subject like selecting the right machinery rating, brand etc so that its flexible enough and commercially viable too.
Any links, practical experiences or information will be highly appreciated.
Thanks
Re: ALUMINIUM DOOR FRAME PROFILES EXTRUSION FACTORY
05/17/2011 10:18 AM
Al profiles are not made from sheet material. They are extruded.
I'd search for aluminum extruders and talk to the varoius manufacturers of the equipment, but you are at a distinct handicap, haveing no experience.
I'd also hire a competent process engineer to start the facility, or you will surly fail.
I'd search for these: aluminum extursions; aluminum extruders; processing aluminum into extrusions; hiring an engineering consultant for start-up.
05/18/2011 12:47 AM
In a nut shell the stages required for the production of aluminium are the following :-
You start with bauxite to extract the aluminium. This is business for big players. You need very cheap electrical energy, cheap source of material and a considerable capital. The Hydro plant in Norway has two buildings 1 km long to do the transformation.
Foundry. You need to make the billets which are cut from logs. So you need a melting furnace and log casting unit.
Logs. These can be bought from specialized companies. If you don't have the technology it is difficult to make quality logs.
Billets. These are what you need for an extrusion press.
Extrusion press. There are a variety of presses available on the market.
You can get a very cheap press from China which has basically no guarantee for performance (200,000 Euro for a 1000 MT press).
If you are looking for a reliable equipment to last 20 years or more , go for a European press. You get the best technology. (800,000 Euro )
You have to select the press based on the final product required and the alloy. You may want to work only on doors and windows with a 6000 series of hard alloy with a 7000 series.
If you are thinking of making only doors and windows the smallest press may be too big for you so think of and alternative requirement (automobile, hardware etc)
Handling systems. There are many available, more or less reliable. These systems can be also fabricated on site. You can spend anything from 100,000 Euro to 1,200,000 Euro.
Surface treatment. You can have the extruded aluminium anodised ( 1,500,000 Euro) or powder coated, or PVDF coat. (1,000,000 Euro)
At this point you have material to make you doors and windows. Here the variety of systems available are infinite. You can have curtain walls, systems that go from 100 mm (section height) to 30mm. Mosquito frames are 8 mm. The requirement normally depends on the country you will supply to. In Europe you would normally use thermal break windows.
You shouldn't spend more than 1,000,000 Euro for a reasonably good production plant.
Now my advice.
To start any business you need money, so
  1. check if you have the resources
  2. select the activity closest to your budget
  3. make a market research to assure the acceptance of the product
  4. make a financial feasibility study and last of all
  5. make your production line and
  6. good luck.
Get some professional people to work for you. you don't need to invent the wheel.
05/18/2011 3:06 AM
thanks for your overview of the processes involved.
for the time being, i am only focussing on having profiles for doors, windows and curtain walls. so i need the optimum machinery for this. could you suggest me a few good european companies dealing in this, coz most of the companies i googled were from china. i am not in favour of chinese companies.
i hope you will be helpful again. you already got one vote from me.
05/18/2011 3:53 AM
Hydro aluminium systems is the top of the market.. Metra Infissi has about everything from cheap to expensive. Bodega has also internal partitions and systems for solar panels. However all these work on European standards. These companies sell systems. They will advice you which is the best machinery to buy based on your production requirement.
Some producers of machinery
Fom, Emmegi, Tecna , these are companies I know that make good machinery but there are many others.
In Italy you have a large choice of anything for Aluminium but go for known names, there are many inventors that haven't got it right.
05/18/2011 6:44 AM
hi angelo,
thanks for your valueable comments. i am glad this forum still has guys like you who are sincerely trying to help others rather than commenting just for the sake of commenting.
you get one more point from my side.
thanks again !
Good Answers: 181
Re: Aluminium Door Frame Profiles Extrusion Factory
05/17/2011 11:17 AM
Your either very versatile or a daydreamer.
Telecom's, distribution engineer and now window manufacturer. It was only January that you were consulting engineer for a project you knew nothing about, what's your role now?
Good Answers: 266
05/17/2011 5:04 PM
Aluminum profiles for windows and doors in not very green. Aluminum will not pass the energy standards here in the USA. So the majority of doors and windows are of vinyl.
05/17/2011 5:22 PM
Oh, ozzb, you can't just say that and leave it.
"Aluminum profiles for windows and doors in not very green." Aluminum is one of the easiest materials to recycle. The aluminum door frame you install today was once a beer can or trim on an automobile.
"Aluminum will not pass the energy standards here in the USA." What 'Standards'?
"So the majority of doors and windows are of vinyl." Can you substantiate this? I certainly cannot.
Janus, please forgive my friend ozzb. He means no disrespect!
Good Answers: 266
05/18/2011 8:02 AM
Just because it's easy to recycle does not mean it's the best material for the application for saving energy.
As far as what standards those set by NFRC http://www.nfrc.org/. Which Energy Star adopted as their mark of performance on u value. Which was about the rating the Fed gave the tax credit for.
http://www.energystar.gov/ia/partners/prod_development/archives/downloads/windows_doors/WindowsDoorsSkylightsProgRequirements7Apr09.pdf
Can the aluminum products be made to meet these standards sure they can. They are extruding thermal barriers in the products. Don't know how recyclable that they will be. These are mostly being used in high rise buildings. Where most vinyl products can not handle the forces.
But even there in products like curtain wall some of the better products for energy savings are being replaced with vinyl. Vinyl covered structural steel tubing that is.
http://www.astrasealdownloads.com/files/CurtainWallingBrochure.pdf
05/18/2011 9:42 AM
I suggest you INVEST a year of life working in such a factory doing whatever job is asked of you. You'll gain far more knowledge than a post on CR4 could ever afford you.
Register to Reply 10 comments
angelo (2); Doorman (1); Fredski (1); lyn (1); ozzb (2); TonyS (1); v1406 (2)
You might be interested in: Door Operators, Door Stays and Lid Stays, Doors
