Previous in Forum: Steam Turbine Governor Types   Next in Forum: Aluminium Door Frame Profiles Extrusion Factory
If DCS Fails What to Do
05/17/2011 3:36 AM
sir, 35 mw turbine and boiler system dcs system fails, what to do
Re: if dcs fails what to do
05/17/2011 3:39 AM
Punt? Pray? Go home?
Ideally, there should be "hard-wired" mechanical controls in addition to DCS/SCADA/PLC systems.
05/17/2011 4:07 AM
The safety valve may lift.
The burners will shut down.
Turbines will slow to zero r.p.m.
Then, everything goes quiet after a while.
Re: If DCS Fails What to Do
05/17/2011 3:35 PM
Remain calm, every site is designed a little differently and the staff hired specifically to maintain and control the site will jump into action and fix the problem (or at the very least safely shut down the plant while the DCS is fixed).
That is what they were hired to do, if you are one of them then talk with your manager regarding what you should be doing.
jack of all trades (1); PWSlack (1); Tornado (1)
