I forgot my password.
Don't have an account?
what will happened if we give command on critical speed of steam turbine?
#25 here is the quick answer. There are other points covered as well. This would be a good starting point for further research. Bringing the turbine to critical speed should be covered in the documentation for your particular unit.
http://www.massengineers.com/Documents/QASteamturbines.htm
Interesting reading Kramarat.
Thank you Mr.Kramarat. Very good and interesting reference.
Dear Mr.RAZAK,
RESONANCE WILL SET IN and prove to be DISASTOROUS. That is why we should CROSS the CRITICAL SPEED QUICKLY.
DHAYANANDHAN.S
