Previous in Forum: Combined Plant Availability   Next in Forum: Anes E-Z Power Converter
Centrifuge Motor
05/23/2011 7:52 AM
I have project, searching for centrifuge motor.
The speed 25000rpm
The torque 200Nm - The estimate power 300Kw
would appreciate leads to manufacturers that make the motor
Thanks > robert email me >
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Pathfinder Tags: Centrifuge motor
Re: Centrifuge motor
05/23/2011 8:05 AM
What's it for?
Would a speed-change-up gearbox be a better bet?
Good Answers: 183
Re: Centrifuge Motor
05/23/2011 1:37 PM
I have some doubts about your power estimations. If the 200 Nm torque has to be maintained (which is exaggerated I am afraid) at the speed you mention then it is over 300kW ( about 500kW).
When a centrifuge works the power requirements are related to frictions in the bearings and between the envelope and environment. For very high speeds the centrifuge which has anyway to be in a protective envelope (for safety in case of accidental destruction) works with a high degree of vacuum in this envelope so that friction with air is drastically reduced.
Let assume that you rotate a thin ring, the maximal radius is :
Rmax<(Re/(Rho*omega^2))^0.5
If the ring is made of high resistance steel at 25000 rpm its diameter has to be <280 mm.
With such a diameter even in air you cannot reach the 300 kW. Some thing is wrong some where. What for do you need such rpm ? isotope separation ?
05/23/2011 11:16 PM
We use the simple relationship of P=TW to relate the power 300kW to torque of ~120Nm when spinning at 25000RPM.
We can consider a 9000 rpm high with frequency inverter and we can gear up 3x We now need help to find manufacturers that could provide such a motor
Good Answers: 183
05/24/2011 5:51 AM
How did you come to the 120 Nm ?
If you rotate in air at atmospheric pressure and 20°C such a torque occurs by about 8 to 16 m cylinder length (d=280 mm) depending on the boundary layer thickness.
I am asking myself what for such a device could be used and you did not answer the question in previous comment.
As for the motor you can find it by yourself using google or other search engine.
Register to Reply 4 comments
nick name (2); PWSlack (1); robertchew (1)
