Hello,
I troubleshoot a 180KW caterpillar genset, the problem is no voltage output. I try to flash the exciter using 24Vdc battery with series resistor 3.7 ohms / 7 watts, then start again the engine but still failled. Then I put DMM to measure the output generator phase i got 8vac only. i try again connecting the battery to the exciter field while the engine is running and observe the output voltage, holding it for 10 sec. the voltage rise untill 20vac only and back to 8 vac when the flash voltage is remove. I had measure the flash voltage on the exciter connector its stop rising untill 11.5vdc. The coil resistance of exciter stator is 3 ohms. its a 37vdc 7.7Amp exciter. I have tried new AVR R448 still failled to generate output.
My question is how much output voltage will be generate if the exciter is 11Vdc?
and base on the above situation , is it the main field exciter problem? Can somebody advice me.
Thank you.
dar76
