Previous in Forum: Flashing Exciter Field Coil   Next in Forum: How Can I Choose the Wires for Surge Arrester
Continuity testing
05/24/2011 4:20 PM
What is the recommended test voltage to be applied when carrying out a continuity test of protective conductors of a wiring installation.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Continuity testing
05/24/2011 10:00 PM
According to IS:732(Part III)-1982
The DC(a battery) test voltage is unknown but the procedure is to measure the earth terminal and farthest installation terminal so that the ohm-meter should not read more than 1 ohm.
If the installation is large each sub-circuit should be measured separately.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
05/25/2011 6:58 AM
I am Agree with Our Friend Hithuanand, For conticuity testing not required to know the value DC voltage of Ohm-meter.
There is no any recommended test voltage for carrying out a continuity test of protective conductors of a wiring installation.
As per IS 732-1989, Clause 12.3.3, Every protective conductor shall be seperately tested to verify that it is electrically sound.
For insulation resistance measurement of protective conductor, the test voltage shall be:
For extra Low voltage Circuits - Up to 250-500V
For 250-500 V Circuits - 1000V
For Circuits above 500V - 2.5KV
Vinu_Answers Sure Answers
Sure Answers Always
05/25/2011 7:57 AM
By definition, continuity testing requires the passing of a current to prove the continuity of the conductors.
Register to Reply 3 comments
hithuanand (1); PWSlack (1); Vinu_Answers (1)
