Previous in Forum: Heat Transfer??   Next in Forum: One Thing About Aluminum Rolling
Minimum diameter size for pressure vessel as per ASME Code
05/24/2011 2:58 PM
Dear All,
I would like to know the minimum diameter size for pressure vessel as per BPVC Code.
any suggestion to doubt is much appreciated.
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Re: Minimum diameter size for pressure vessel as per ASME Code
05/25/2011 12:40 AM
there is no min. size value as per ASME. the formula given in that has to be used to find out the thickness value. refer ASME Sec. 8 div. 1.
Varun Passi
05/25/2011 1:21 AM
The BPV Code may have changed over the years, but I think there used to be a provision that vessels smaller than 6 inches internal diameter were exempt from the Code.
03/04/2014 6:23 AM
is there any reason to consider the vessel with less than 6 in in diameter as NOT pressure vessel?
Register to Reply 3 comments
Conan21 (1); Tornado (1); varunpassi (1)
