Previous in Forum: CMC or Computerised Material Cutting Machine for Prepreg?   Next in Forum: Best Place to Take Oil Sample from Hydraulic Circuit
8 comments
Mr Ewen Burn
05/26/2011 11:36 AM
Is there anyway you can fit metal protective finger tips to the inside of Gloves worn on a re cycling plant,if so can you help me or make them for me.
Re: Mr Ewen Burn
05/26/2011 1:16 PM
There is a specialty glove for the skateboard crowd called a 'Slider Glove'.
While the metal protection is outside the glove, these may be a solution.
As an alternative, the gloves used by fencers stringing barbed wire may work, but they are pretty stiff and are sort of uncomfortable.
Re: Mr Ewen Burn
05/26/2011 1:24 PM
Would the kevlar gloves worn in meat packing plants work for you?
Re: Mr Ewen Burn
05/27/2011 11:53 AM
Thanks for that but with this job it is touching everything,need finger movement,protection on the end of the fingers.
Landscape
Re: Mr Ewen Burn
05/26/2011 9:10 PM
What about sewing thimbles inside the gloves.
Re: Mr Ewen Burn
05/27/2011 11:50 AM
Ya thanks for that,I had already thourght of that I just want to speak to the makers so i can tell them,thanks again for your in put.
Landscape
Re: Mr Ewen Burn
05/26/2011 10:14 PM
Gloves are also made of fine chain-mail, to prevent cuts in butchering facilities, for instance.
Good Answers: 181
Re: Mr Ewen Burn
05/29/2011 7:30 AM
If there were a possibility of hypodermic needles then chain mail wouldn't help. The thimble idea sounds reasonable.
I can see the problem, armour required along with flexibility. But how to achieve it?
Re: Mr Ewen Burn
05/29/2011 11:20 AM
Hi Tonys,thanks for you input but I think I my have someone who will help me with this idea,I am waiting for an answer with in the next week,Iam sure that armour can be put in gloves,unlike steel plates in boots,those are flexable enough,lets wait and see.Thanks again.
Landscape
dgibson (1); Doorman (1); Landscapes (3); lyn (1); TonyS (1); Tornado (1)
You might be interested in: Safety Gloves, Welding Gloves, Protective Packaging
