Previous in Forum: Battery Charging Mishap   Next in Forum: CT Ratio
24v AC an 24v DC over 600 ft
05/26/2011 10:47 PM
First off, hello everyone!
I stumbled across this forum today and thought myabe you guys would be able to help me...
I am running a whole whack of control wiring from an office control room to various soft-start motor starters, and many other things.
Now, the blue prints call for 16 or 18 awg wire to be run, but over 600 ft i would expect a voltage drop and was thinking i'm more than likely going to need a larger gauge for this.
Would 14 awg be suffienct? Perhaps 12?
Anyways thought maybe someone would be able to help out, i'm just an apprentice it'd be nice to help the boss out with this one ;)
Look forward to browsing the forum!
Re: 24v AC an 24v DC over 600 ft
05/26/2011 11:07 PM
If you go to the "search this forum" window on the right you will find many references to voltage drop, such as Voltage Drop Formula
You could also search for the solution and find sites such as this:
Voltage Drop Calculator - Southwire
How to Calculate Voltage Drops
COMPREHENSIVE VOLTAGE DROP CALCULATIONS
Voltage drop - Wikipedia, the free encyclopedia
Check out some of these sites.
05/27/2011 3:52 AM
If the control signals are 4-20mA, then the proverbial "two bits of wet string" would do.
British Standard 7671, anyone?
05/27/2011 11:27 PM
Hi Pinz, I could never get my head around awg, over here we use the metric system.
But you have a 200 meter lead between controller and the controls, the current that you are using is only milliamps for each device, You have to work out how many devices you are controlling and calculate the voltage drop over the circuit.
To do this you need to know and understand a few things;
1: Number of controls to motors
2: Voltage that each of these controls is operating at
3: Current draw of each control
4: Study the electrical schematic and understand just what is happening
When you have done this the answer will be there with a few math calculations.
It is difficult for us to tell you what to do when we don't have all the information, It's a bit like asking "How Long Is a String".
More Information required
Cheers
Joe
05/28/2011 3:07 AM
Aw come on Joe, you know the length of a piece of is string is 2 x L/2.
05/28/2011 12:15 PM
A 12 awg COPPER wire would give a voltage drop of approx 2 volts per amp at a one way distance of 600 ft ( which is about 10 percent of control voltage)and hence you need to calculate current in each ciurcuit precisely and decide the wire size.
PRIYADARSHAN
05/28/2011 10:08 PM
ELEMENTARY OHM's law
12 G if you don't care for money.
20 G IF YOU ARE A PENNYPINCHER
05/30/2011 10:31 PM
Thanks guys, I realize i have to get the amprage for all these devices (approx 100 low voltage runs), unforunatly the draw is not labeled on the schematic/prints so we have to give the engineer of this project a ring.
Will update, thanks for the help!
Register to Reply 7 comments
JIMRAT (1); Joe Sparky (1); lyn (1); MUKULMAHANT (1); piNz (1); Priyadarshan (1); PWSlack (1)
