Previous in Forum: Switch Gears   Next in Forum: Installing Grab Sampler and PICO Controller Instruments
Simens HMI Touch Screen Display Breaks
05/28/2011 8:31 AM
i have one Siemens HMI ( TP170B, 6AV6-545-OBB15-2AX0) FOR MY plc 313C. its DISPLAY got breaks few days back. Since its very long model i couldnt find out the same model. But i have another HMI(TP177, 6AV6-640-OCA11-0AX1), i think this model is for S7 200 series. My question is can i interchange both the displays( i mean the touch screen)? If i changed the display unit is it works?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Simens HMI Touch Screen Display Breaks
05/28/2011 10:49 AM
If the two touch screens have the same function. LOL, you cannot change a lift touch screen by a electrolysis process one.
Anything that can go wrong, will go wrong
Good Answers: 117
05/29/2011 7:22 AM
No... you will have to contact Siemens
04/23/2019 2:39 AM
Yes, in fact, from the technical parameters of the touch screen, the two screens are the same size and function, you can rest assured. Or you can buy a new touch screen for TP170B, 6AV6-545-OBB15-2AX0 replacement directly at the Siemens Simatic HMI Part Center.
VICAPS HMI Parts Center: Touchscreen-Keypad-LCD Displya-Protective Film
Register to Reply 3 comments
brich (1); hien.nguyenquoc (1); VICAPS HMI Parts (1)
