Previous in Forum: UPS Calculation and Diversity Factor   Next in Forum: Low Current Electricity
Bus Bar
05/29/2011 1:29 AM
how to calculate bus bar voltage drop calculation in genral.
Re: Bus bar
05/29/2011 1:50 AM
This has to be a homework or take home exam question. I hope all of these lazy bums fail their class.
Re: Bus bar
05/29/2011 2:02 AM
E = IR (for DC or single phase). I think it is E = √3IR/2 for 3-phase, but I haven't done this for a while. For bus bars of short length, R is almost zero, so I am surprised that anyone bothers to calculate it (as opposed to long conductors with small cross-section).
Engineering Fields - Electrical Engineering - Hentoyk Philippines - Member - BRUTUS Saudi Arabia - Member - Brutus United Arab Emirates - Member - Brutus
Re: Bus bar
05/29/2011 2:44 AM
Voltage drop at bus bars are neglegible because it is the point wherein close to supplied loads. What you need to calculate is the feeder cables from the power source where your MDB busbars is getting its power. Allowable Voltage drop from point "0" or power source to the farthest circuits not in the MDB or busbar point but to the farthest supplied circuits- shall not be more than 5% of supply voltage.
Voltage drop formula:(English system)
Vd = (2xKx I x L)/CM - SINGLE PHASE 2 or 3wire
Vd = (1.732 x K x I x L)/CM - three phase
where:
K = resistivity of cable per 1000feet, value changes with temperature and size of cable.
L= Length of cable/conductor in feet
CM = Circular mil area of the conductor
I = Load current in amperes
If there is a will... there is a way... No pain / No gain.
Register to Reply 4 comments
Anonymous Poster (1); hentoyk (1); redfred (1); Tornado (1)
