Previous in Forum: Bus Bar   Next in Forum: Power Loss In A Relay
Low Current Electricity
05/29/2011 3:27 AM
how to provide the low current to a huge building .explain from the out coming 11 kv supply to a single distribution board in technical terms also in a simple language presentation.
Good Answers: 181
Re: low current electricity
05/29/2011 4:08 AM
Homework?
05/29/2011 6:43 AM
Hire a competent electrical engineer. Is that simple enough?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
05/29/2011 8:12 AM
We normally provide it from the substation in the undergound floor. What else you want to know more?
Anything that can go wrong, will go wrong
Re: Low Current Electricity
05/30/2011 2:18 AM
I think you may mean low voltage, rather than low current. In some locales, for power distribution purposes, anything below 1000 volts is considered "low voltage." The usual scheme is is for a medium voltage supply to feed a transformer (mounted on a pad or platform outside the facility), which in turn supplies a locally standard low voltage (575, 480, 415, 380, etc.) to the facility's switchgear. This is not etched in stone; there are also medium-voltage plants such as 4150, to pick one example.
Register to Reply 4 comments
hien.nguyenquoc (1); lyn (1); TonyS (1); Tornado (1)
