Previous in Forum: Project Engineer-Electrical   Next in Forum: Why Squirrel Cage Rotor Type Induction Motor's Rotor Bar Placed In Skewed Form?
19 comments
Genset Earthing
05/29/2011 5:43 AM
Dear Members,
What are the factors to consider for earthing a generator set. what calculations are involved in sizing the earth cable?
Should the small mobile gensets for households be earthed?
Pls explain these set duty terms and their applications:
ESP, prime, continuous
regards
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Genset Earthing
05/29/2011 7:25 AM
Every equipment, if it is not rated as Class II or received power from low voltage isolation transformer. Then, it should be earthed.
Anything that can go wrong, will go wrong
Reply Off Topic (Score 3)
Good Answers: 181
Re: Genset Earthing
05/29/2011 9:04 AM
Having worked on 660V 3MW systems that are earth free I'd take issue with that.
You can't just make general statements, for most situations you would be right but not all!
Re: Genset Earthing
05/29/2011 9:24 AM
Show me that, TonyS. I have never seen any electrical equipments unearthed except class II. You are from England, you may know very well about PAT.
Depend on the situation and depend on what I really know, I don't have time to give the details as much as possible. The OP will understand it himself. You stated that 660V and 3MV, it is also so general, I cannot understand what is that. I also don't want to see the fights against each other here. That is not my purpose.
Good Answers: 181
Re: Genset Earthing
05/29/2011 10:27 AM
Simple it's a lot of power that is not earthed.
I only worked on it for 12 years and redesigned the power regulation. I think I know it exists.
And by the way it's 3MW
Good Answers: 181
Re: Genset Earthing
05/29/2011 10:44 AM
You've upset people on this site this weekend, you say you don't want to start arguments. You've a bit of bridge building to do!
Good Answers: 117
Re: Genset Earthing
05/30/2011 1:55 AM
Got to disagree with that bit of your post.... looking at the question and moreover, understanding the question, it would seem that if the OP did understand "earthing" then he would not be asking the question, so as TonyS says" You can't make general statements".....generalising is another way of saying something without any substance.. politicians do it all the time
As for PAT.. do you mean "Portable Appliance Testing"? Pray tell, what does PAT have to do with earthing of a generator? Last time I checked a 3MW gen set is not that portable!
Re: Genset Earthing
05/30/2011 2:55 AM
Just put big enough wheels on it! (Aggreko may already have some that big.) But dangling a grounding chain off it probably won't be good enough.
Good Answers: 117
Re: Genset Earthing
05/30/2011 4:14 AM
Yes... and a towing hitch on your truck and away you go!!
Good Answers: 181
Re: Genset Earthing
05/30/2011 5:42 AM
Who say's it's not portable, last I heard it had moved from the UK to Spain. Took a bit of shifting by all acounts
Good Answers: 117
Re: Genset Earthing
05/30/2011 5:49 AM
the grounding chain.. perchance an anchor??
Good Answers: 181
Re: Genset Earthing
05/30/2011 9:07 AM
Just hope it took it's UK pension papers with it, it's old enough.
India - Member - New Member
Re: Genset Earthing
05/30/2011 10:58 AM
@ hien
I am a beginner only so Can you please explain class 2 in somewhat more detail so that i can read well from net or refer some book for further studies..
A.Classy.Lass
Re: Genset Earthing
05/30/2011 11:09 AM
Ok, it is implying portable electrical equipments in term of safety level. Class II means the electrical equipments which have two classes of insulation. The first one is called basic insulation (like motor windings), the second one is called double insulation (like plastic cover).
So, we will have many class II equipments such as drilling machines... But remember that they belong to the portable equipments only. Since the definition of Portable equipments are very wide and the OP asked for household generator. In a certain aspect, it can be considered as portable one. That is why I posted my answer.
Hope it helps.
Re: Genset Earthing
05/30/2011 11:17 AM
Thanks a ton..
Now I can build up my concept on the information you provided.
With Warm Regards,
A.Classy.Lass
Good Answers: 170
Re: Genset Earthing
05/29/2011 9:08 AM
i) Zero sequence impedance of the generator, maximum permissible earth fault current magnitude & duration, etc.
ii) Yes! More so, with hosuehold gensets, where the danger of electrocution is more prononced as non-technical people ca and will handle electricity.
iii) ESP - Electroststic Preceipitator (or) Electrical Standard Products (or) Extra Sensuory Perception
iv) Prime & Continuous mean the same.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Genset Earthing
05/30/2011 7:23 AM
Yes, the earthing of standby and other private generating plant (including portable and mobile generators) is necessary to protect against indirect contact that may result in electric shock. The objective is to create a zone in which voltage between exposed conductive parts get minimized in the event of an earth fault.
Various factors like generator per unit impedence, fault current levels, system criticality, duration of fault current, etc.
Approximate resistance to earth of Metal plate can be calculated from:
R = ρ/A ( π/A) Ohms.
Where, ρ = resistivity of soil in Ohm-meter and A = area of both sides of plate
Resistance of rod or pipe electrode is given by,
R = 110ρ/2πL*(loge 4L/d) Ohms
Where,
L = Length of rod or pipe (in cm),
d = diameter of rod or pipe in cm and
ρ = resistivity of the soil in Ohm-meter.
May be this will help you.
Sure answers always...
Sure Answers Always
Anonymous Poster #2
Re: Genset Earthing
05/30/2011 9:18 AM
Verbal diarrhoea.
Good Answers: 117
Re: Genset Earthing
05/30/2011 9:21 AM
give him a break..he's a newbee!!
Re: Genset Earthing
05/31/2011 4:02 AM
British Standard 7671.
Reply to Forum Thread 19 comments
A.Classy.Lass (2); Anonymous Poster (1); brich (4); electricalexpert65 (1); hien.nguyenquoc (3); PWSlack (1); TonyS (5); Tornado (1); Vinu_Answers (1)
