Previous in Forum: Unstable Voltage   Next in Forum: GE Multilin SR735 Feeder Protection Relay Failures ?
12 comments
Function of Reversible Contact in Lower Size Pump Motor Circuit
06/01/2011 12:36 AM
What is the function of reversible contact in lower size pump motor circuit?
thanks
Saraswata
Re: function of reversible contact in lower size pump motor circuit
06/01/2011 12:40 AM
It depends on specifics. For some types of pumps, if the pump gets clogged, running it backwards might clear the blockage.
06/01/2011 12:48 AM
Reversible contact allows the pump to work in both the Northern Hemisphere and Southern Hemisphere without replacing the contacts when crossing the Equator. (See Coriolis Effect)
This is not to be confused with the multi-hertz contact that allows operation at both 50 and 60 hertz, but is not hemispheically sensitive.
Hope this helps.
06/01/2011 1:03 AM
I have seen in few projects -- for higher size motors this contacts are not used.. What is the reason behind?
Good Answers: 145
06/01/2011 1:18 AM
06/01/2011 1:27 AM
I'm headed for the naughty step, I just know it.
06/01/2011 5:38 AM
Del's already on it. Find another one....
Good Answers: 58
06/01/2011 8:27 AM
Hey, this step is getting crowded
Good Answers: 181
06/01/2011 2:56 AM
Sounds plausible to me
06/01/2011 11:01 PM
In the pump casing of centrifugal pumps direction rotation of shaft/impeller is marked permanently. If we change direction of rotation in either northern or southern hemisphere
will the rate of flow change?.
pnaban
06/02/2011 2:57 AM
Yes. Wrong direction = lower flow and less pressure capability.
Re: Function of Reversible Contact in Lower Size Pump Motor Circuit
06/01/2011 8:18 AM
May be for chosing the right direction of pump. without changing the phase sequence / terminals , to be user friendly & convinient for house people to use pump properly.
Exploring the Science of Electricity
Good Answers: 804
06/01/2011 4:37 PM
I can think of two reasons, one already expressed by Tornado and the other alluded to by Harry Potter:
  1. Reversing of grinder or chopper pumps that become jammed
  2. Maintaining proper rotation on 3 phase motors when powered by emergency generators. Most sewage lift station pump stations and many water booster stations are fitted with plug-in portable generator receptacle so that they can be powered in emergencies. In several cases I have worked on, they wanted them to be powered by any Em. Gen, but for whatever reason the Fire Dept. generators were not coordinated with the Sewer or Water Dept. Em. Gens., so in case the FD got there first, they would have to change rotation to make the pumps work.
Register to Reply 12 comments
harry potter (1); JRaef (1); KJK/USA (1); lyn (2); pnaban (1); PWSlack (1); saraswata1981 (1); Tobugrynbak (1); TonyS (1); Tornado (2)
