My Acer Aspire one ZA3 first started giving trouble about 2 months ago and gradually this problem got worse and worse until now. At the beginning this issue first manifested itself when I got a total freeze up using Word. I would be writing a document and scroll up or down through the document when suddenly everything would freeze solid. Absolutely nothing could be done so to clear the freeze up I would have to hold down the power button about 10 secs. This would force the unit to Off. Now after waiting a short period I'd start up again and everything would be ok again. As time went by this event repeated itself often and one time it happened when I answered a Skype call but this time I was unable to restart the unit. I took it to a group of technicians and of course it started for them OK (Murphy's law). They downloaded all my things just in case. Finally after a few more failures it now will not start. But the strange thing is that it seems to try to start then quits. When I press the on/off button the green LED comes on for a second as well as the 2 LED's just to the left (marked with 2 little padlocks) and the little red wireless parabola symbol lights. If I put my ear to the spot just to the right of the finger board I hear a humming sound as well as an attempt to start from the HDD. I believe it begins to turn then stops, waits a second, then tries again. This goes on forever. I took it to my guys again. They removed the HDD and tested it saying it was OK. So now what options do I have left?
The battery is new and the charger works fine.
I'm not a computer expert, just a normal type user.
thanks
john
