Previous in Forum: LED Project Help   Next in Forum: Capacitive Load Alternative
14 comments
Ground Rod
06/05/2011 12:32 AM
Hi All,
what is the standard requirement installing earth rod or ground rod, Is it allowed to add-in ground enhance material " bentonite, Charcoal, salt/water" too lower the resistance?, Because i've been attending many inspection with regards to the ground rod installation and don't see any such material.
Regards
Re: ground rod
06/05/2011 1:02 AM
Pi$s on it.
Re: ground rod
06/05/2011 1:57 AM
What happens if you pi$s on a grounding rod/pit that doesn't have good conductivity? What about bare feet vs. rubber boots?
Reply Score 1 for Off Topic
Re: ground rod
06/05/2011 9:53 AM
Now that's sick. I'd never pi$s on a grounding rod bare footed.
Re: ground rod
06/06/2011 11:14 AM
SOP for Signal Corps field sites.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: ground rod
06/05/2011 1:50 AM
According to IS: 3043-1966 We have (Rod and pipe electrodes earthing) and (Plate earthing). Rod of GI should be atleast 16mm in diameter and those of copper atleast 12.5mm. 2.5m in length covered 15cm of sodium chloride,calcium chloride,sodium carbonate,copper sulphate in 3 layers. Add water subsequently to improve the conductivity of soil hence reducing the resistivity.Remember ideal ground should be of zero potential. How you become an inspector?
Re: ground rod
06/05/2011 5:01 AM
Be more specific-first howmany cm of earth,then 15mm NCl,then 15cm earth,then 15cm CaCl,then 15cm earth,similarly NaCo3&CuSo4.Is it correct?. Don't you use a mixture of common salt and charcoal
pnaban
Anonymous Poster #2
Re: ground rod
06/05/2011 5:14 AM
You do what lyn and Tornado said.
Anonymous Poster #3
Re: ground rod
06/05/2011 11:10 PM
How you become an inspector? i toke onlin course now i is one
Re: ground rod
06/06/2011 10:01 AM
What will be the long term effect on electrodes by these chemicals?.
pnaban
Good Answers: 181
Re: Ground Rod
06/05/2011 6:56 AM
Spread urea on the surface and water it in. It's a bit more hygienic.
Re: Ground Rod
06/06/2011 4:01 AM
In the absence of a large quantity of urine, try seawater.
Re: Ground Rod
06/06/2011 6:07 AM
I guess it would depend on where you reside. I did a google search a few years ago for grounding . I believe it said that in Wisconsin , and other Northern states is was the law to use Bentonite, or a suitable substance in all grounding. It certainly has helped me. I poured Bentonite into a few holes here, with a copper ground rod, and my grounds all work great. Good grounds means much less maintenance for me, and my ham radio equipment sure likes it. My towers are grounded this way also. I have never lost a tower or equipment to faulty grounds, or lightning strikes. If its not the law of the land where you reside, then it should be. To me it is just good common sense. Bob KC0VEA
Life is tough, but it`s tougher if your stupid, John Wayne.
Re: Ground Rod
06/06/2011 9:59 AM
What will be the long term effect on copper by Bentonite?.
pnaban
Re: Ground Rod
06/06/2011 10:20 AM
None that I am aware of??
Anonymous Poster (2); Brave Sir Robin (1); hithuanand (1); lyn (2); pnaban (3); PWSlack (1); rcrain (2); TonyS (1); Tornado (1)
