Previous in Forum: Circuits on Higher Voltage   Next in Forum: Current vs. Voltage
8 comments
LV Current Transformer
06/05/2011 11:40 AM
i have doubt about the connection of LV current transformer ratio 1600A/5A with neutral or ground.can anyone give the details.
Re: LV current transformer
06/05/2011 12:45 PM
Never play around CT.
Good Answers: 181
06/05/2011 12:56 PM
Tell us your doubts, we may have something to work with then.
As out mysterious guest says DO NOT interfere with CT connections unless you know what you are doing.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: LV Current Transformer
06/06/2011 3:43 AM
You have not written your doubt, pl. give complete details. Are you in need of connection diagram?
Sure Answers Always
06/06/2011 4:14 AM
In two wire of busbar current transformer (1600/5A), one wire we can connect with ammeter selector switch and my doubt is another wire whether we can connect with neutral or ground in three phase measuring purpose.
Good Answers: 181
06/06/2011 6:34 AM
06/06/2011 7:57 AM
Neutral also finally connected with ground with small resistance value.is there any problem to connect with portable generator neutral.
06/06/2011 3:58 AM
The question is what, please?
06/06/2011 4:07 AM
Ground.
You have nothing to do with the neutral
dont say it, write it
Register to Reply 8 comments
Anonymous Poster (1); Le_Noble (1); mohamedhajah (2); PWSlack (1); TonyS (2); Vinu_Answers (1)
