Previous in Forum: Lithium polymer electrode coating   Next in Forum: machinery for motors ?
Low Friction Paints
04/13/2007 7:34 AM
I'm wondering if anyone has had any experience using low friction paints or coatings. I want to coat the inside of a prototype hopper that has moveable dividers that ride up against the two inside walls. These dividers provide a seal and also channel the material into separate chutes at the bottom of the unit. The seal is made by thin plastic pieces that push up against the walls of the hopper. I would like to make the plastic slide a little better by using a coating on the inside walls of the hopper. I have been looking at some paints and dry graphite lubricants but I'm unsure how well they will hold up in this application. As the dividers are moved to accept different flows of material they will be scraping up against the inside walls that I will be coating.
I'm looking at this type of solution because wet lubricants are not an option in this project. I also want to buy a coating that can be applied at our facility. Sending the unit out to be coated is not an option for the prototype. I have included the links to two of the companies I have been looking at. Any suggestions or advice that anyone has is greatly appreciated. Thanks.
Re: Low Friction Paints
04/13/2007 8:10 AM
Look at a Molybdemion... I know I didn't spell that right, we just called it Moly B.... it was a coating that we applied by paint brush and it worked very well.
The vapors are very hazardous, we had a different person apply the material everyday, if anyone applied it two days in a row, they were out sick on the third day. It seems it took more then 24 hours to flush out of the system and two days straight was tuff on the people.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
04/14/2007 6:44 AM
Don't know what you are putting through that hopper; but if its consumables, you don't want to use graphite or Molly.
Ships paints are formulated to be low-friction to assist the vessels in both barnacle prevention and fuel efficiency. Some of them are toxic, however. You will have to investigate them and discover which are non-toxic.
There are also some pretty tough teflon coatings.
Mark
04/14/2007 8:28 AM
We manufacture paints with Teflon additive in. This provides a good abrasion resistance AND nicer flow of product in hoppers. Use extensively in the mining industry, the pulp and paper and wastewater plants, these paints are in use for the past 20 years.
If you want more information send me an email, I will be please to help you out on this.E-Mail: mdumaine@stoncor.com
You may need a polyurethane coating wich is more fexible and easier to repair than epoxies... We use polyurethane in street sweeper hopper instead of glued rubber...I can also provide names for applicators going to your shop doing sandblast and coatings.
Hope this can help
04/14/2007 10:36 AM
I've used a similar product, "Graphite Plus" which comes in an aerosol spray can and is made a company names Asbury Carbons. It's like a spray paint. My application was electromechanical and I needed something that was a good conductor. However, it is also meant for sliding mechanisms like the one you mention, elevator guides. It sprays on easily, and it has taken some abuse without failing. You could buy a single can and test it with your material, if you have some left. Make sure it adheres etc.
As others stated, it's probably not a good idea to use it if it will come in contact with food. Request a material safety data sheet. A teflon coating would probably be better.
I do not understand why you are considering a hydrophobic silicon when it is a dry application, unless that is the material that you are trying to further lubricate. If your application is more extreme, you may want to consider sacrificial metal sheets/plates to bear the abrasion. Good luck with your prototype.
04/21/2007 12:41 AM
Rather than a 'paint" maybe consider fiberglass, which would wear longer, also,
Better...i would also consider laying in specialised blend of nylon or similar plastic membrane up to .062 " [1/16"] thick... lasts very long time, nylon is rather benign if some micro residue gets in to product [inevitable if any friction involved] it is self lubricating and very inert, tolerates medium temps.
J Bo
Anonymous Poster (2); Labyguy (1); Madmax1997 (1); MarkTheHandyman (1)
You might be interested in: Retaining Walls, Industrial Paints, Curtain Walls
