Previous in Forum: Joining Two MSBs   Next in Forum: Series/Parallel Capacitor for Motors
effect of power factor
06/08/2011 4:46 AM
wat wil happen if we disconnect one phase of 11 kv metering during offseasonal industry ?mean to say is there any effect on power factor on billing during disconnection?
Re: effect of power factor
06/08/2011 6:28 AM
If there is no power factor penalty in the tariff, then power will be charged on a kWh basis or a maximum kW basis. So why worry (rhetorical question)?
If there is a power factor penalty in the tariff, disconnecting one phase will mean either that the loads will redistribute across the remaining phases, saving nothing, or that two-thirds of the power will be charged, saving 1/3 of the outlay, or some factor in between. Either way it cannot be seen from here.
Good Answers: 181
06/08/2011 7:49 AM
Disconnecting one phase of the metering will make a considerable difference.
A prosecution instigated by your supplier would be the first.
06/08/2011 8:07 AM
To be fair, CR4 doesn't know whether this is an internal charging meter or an external one.
Good Answers: 181
06/08/2011 10:22 AM
OK then, an a*se kicking from the company accounts department or prosecution.
Good Answers: 181
06/08/2011 10:39 AM
I know about the accounts department, they weren't happy when I swapped feeders around to balance the loading on the main intake board. Meters that hadn't been used for years started clocking up while other meters just stopped.
The engineering was sound but the bean counters didn't like their little spreadsheet being messed up.
Good Answers: 44
06/08/2011 10:55 AM
your distribution transformers may get a little p!ssed...
06/09/2011 3:26 AM
Hoon,,,,,,,,,,, pilferage of power
Register to Reply 7 comments
Anonymous Poster (1); cuba_pete (1); PWSlack (2); TonyS (3)
