Previous in Forum: Programming 89c51 Using Keil C   Next in Forum: Linear Voltage Amplification
want to know about sensor output
06/08/2011 4:49 AM
how would be the output when proximity sensor sense the rotation of the shaft? in shaft magnet is attached at every ration of shaft the sensor get output how it would be?
Re: want to know about sensor output
06/08/2011 6:04 AM
See the sensor manufacturer's datasheet for the device.
Good Answers: 58
06/08/2011 8:15 AM
Sounds like you are referring to a Hall Effect sensor.
Have a look at this website
Good Answers: 125
06/08/2011 3:01 PM
You have a rotary proximity sensor. Most of these devices are connected to a PLC. If you do not understand what you are looking at, don't monkey around with it. Your boss will not be pleased with the result.
Anonymous Poster #2
06/12/2011 5:44 PM
Question not clear rephrase your question
06/17/2011 6:47 PM
You can use a counter or frequency measurement device to get data of the shaft turning. A proximity sensor will have a pulse of 24V or similar (depending on power voltage). That can go to the "isolated input" of a device like I-7080 http://www.icpdas-usa.com/products.php?PID=139 . Then a computer or PLC can read the quantity of revolutions or speed of the shaft.
Good Answers: 116
06/22/2011 8:46 AM
If you have a magnet on the shaft, what you have is probably an "inductive pick-up", not a proximity sensor. An inductive pick-up is basically a coil of wire. When the magnet is right over the end of the coil, the magnetic flux passing through it is high. When the magnet is well away from the coil, the flux in it is small. A voltage will be "induced" [hence the name "inductive pick-up"] in the coil while the flux is changing, due to the movement of the magnet attached to the shaft. Its magnitude will be proportional to : Number of coil turns x rate of change of flux. Therefore peak voltage will be directly proportional to shaft rotation rate. Output waveform is basically a pulse, of a "bell" section shape when drawn on a voltage against time graph.
67model (1); Anonymous Poster (1); KJK/USA (1); PWSlack (1); TechEric (1); WJMFIRE (1)
