Previous in Forum: want to know about sensor output   Next in Forum: RFID ANTENNA DESIGN , is it complicated?
10 comments
Linear Voltage Amplification
06/08/2011 7:16 AM
Dear All,
we are using a 10k, 10 turn linear pot, the output is given to a IC TL084.Two amplifiers in the IC are used to amplify the signal. one volt dc is given to the pot.+12 & -12 vdc are used to the IC. The output is not linear, for one turn itself it reaching around 50 mv & then raising slowly.
Please guide me how to get the linear output.
sorry if my question looks odd.
Thanks.
Re: linear voltage amplification
06/08/2011 7:30 AM
What is the gain of the circuit? What is the circuit configuration?
You need to add resitors to form a circuit with known gain, else the output will just go up and down to rail.
We need a circuit diagram to provide constructive help.
Probably best to build a circuit with a gain of 1 or 2 first to prove it works and then increase it to what you want.
Good Answers: 44
06/08/2011 10:34 AM
Of course, we will want this to go to 11.
Re: Linear Voltage Amplification
06/08/2011 11:41 AM
Yes, a schematic would be very helpful.
The early bird may get the worm, but the second mouse get's the cheese.
Good Answers: 53
06/08/2011 12:25 PM
06/09/2011 2:26 AM
Thanks for the replay.
The circuit is enclosed, please give your valuable suggestion.
06/09/2011 3:02 AM
Can't read circuit, too much white space and irrelevant stuff.
crop it and resize before posting. or draw it by hand and scan it.
06/09/2011 5:29 AM
Use this
free screen capture print tool from: http://www.infonautics.ch/screencaptureprint/
to give us a better view of the schematic.
06/09/2011 8:59 PM
From what I can see.... you have a unity gain buffer after a pot which isn't being used!!!! the input is connected to +5 volts (or something)
You won't get far with this circuit mate..... ask an engineer to design one for you....
06/09/2011 5:57 AM
Here is a paper on Op Amp circuits that might help.
http://users.ece.gatech.edu/mleach/ece3050/sp04/OpAmps01.pdf
Use your 10 turn pot as the feedback resistor (Rf). The gain is the ratio of the feedback resistor divided by the resistor on the inverting input.
Canada - Member - New Member
06/10/2011 8:12 AM
As well as circuit design you may want to make sure the potentiometer you are using does not have a taper built into it. It must be a linear potentiometer.
Elroy
Knowledge makes what was impossible, seem easy.
Register to Reply 10 comments
cuba_pete (1); dcpppf (1); Electroman (1); Elroy (1); rakesh_semwal (1); Randall (1); Rixter (1); TSR (1); user-deleted-1105 (2)
