I have a piece of equipment which utilizes a low voltage (60V) gas filled tube type spark gap. The gap fires to protect sensitive electronics in a impedance matching circuit and is bridged across the impedance matching transformer. For surge protection, the tube is designed to pass a charge of 0.6 coulomb at a tpeak current of 75 amperes in either direction. Glow condition is established within five microseconds ata tube drop of about 70 volts. Tn less than 500 ms the cathode is heated sufficiently by ion bombardment to cause a transition to arc condition, giving a tube voltage drop of about 10 volts.
I have more specs, but that's a good start. My problem is this: it contains a radioactive isotope to aid in ionizing the chamber to speed operation. I don't want to deal with the material and it causes me adminstrative headaches. Disposal is not a problem, I have that covered. My problem is finding a "direct" replacement but which contains no radioactive material. I have been looking at MOV's, but the low voltage requirement makes me think twice about those. I am also space limited. The current device is 1.5 x 2.6 inches, and I don't have much more space than that to deal with.
Now, let the bombardment of questions begin!
