Previous in Forum: Does Dielectric Strength Depend On Thickness?   Next in Forum: Performance of Motor With Soft Starter And Fluid Coupling
Earth Strip Calculation
06/10/2011 1:15 AM
How to calculate the size of earth strip ,wheathre it is copper,al. Some consider based on type of load (inductive, capacitive) and some consider in comer breaker amps of a particular panel .Can u get me a formula that can be used for all the above requirments
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Earth Strip calculation
06/10/2011 5:48 AM
Dear Venkatesh,
The minimum cross-sectional area of protective conductors (earth strip) shall be determined by the following formula:
S = (√I2t)/k
Where,
S = cross-sectional area, in square millimetres
I = value (a.c., r.m.s.) of fault current for a fault of negligible impedance, which can flow through the protective device, in amperes
t = operating time of the disconnecting device, in seconds
k = factor dependent on the material of the protective conductor, the insulation and other parts and the initial and the final temperatures.
k = 159 (for 200º C Max. Temperature) for Copper,
K = 105 (for 200º C Max. Temperature) for Aluminium,
k = 58 (for 200º C Max. Temperature) for Steel.
Note:
1) The initial temperature of the conductor is assumed to be 30 "C.
2) If application of the formula produces non-standard sizes, conductors of the nearest higher standard cross-sectional area shall be used.
3) Maximum permissible temperatures for joints should be taken info account.
Alternatively, value of k may also be calculated by:
k = √[Qc (B+20)/Q20) ln {1+(θf + θi)/(B+ θi)}]
Where,
Qc = Volumetric heat capacity of conductor material [J/ºC mm3]
B = reciprocal of temperature coefficient of resistivity at 0 ºC for the conductor ºC]
Q20 = electrical resistivity of conductor material at 20 ºC [Ωmm]
θi = initial temperature of conductor [ºC]
θf = final temperature of conductor [ºC]
Vinu_Answers Sure _Answers
Sure Answers Always
06/10/2011 10:26 AM
Thank U , Very much sir . I am clear now
06/13/2011 7:09 AM
Very good reply. It will be immensely helpful to Q4 Electrical Engineers.
Thanks,
Manindra
Manindra
06/15/2011 5:14 AM
The minimum cross-sectional area of protective conductors (earth strip) shall be determined by the following :
S = (It)/k
or
S = (I√t)/k
IN calculation the sqt and square will cancelled . so the above formula can also be mentioned . I hope i am right
06/17/2011 1:41 AM
Dear Venkatesh,
S = {√(I2t)}/k
Hope, Formula is clear now.
Vinu_Answers Sure_Answers
Sure Answers Always
06/10/2011 7:28 AM
British Standard 7671 is the only formula needed.
Re: Earth Strip Calculation
04/25/2012 1:02 AM
Requested you explain this formula with some example.
Like: earth strip size for 500KVA Transformer/ for DG set & other small panels as per their load in KW.
Please clarify....
Register to Reply 7 comments
manindra (1); PWSlack (1); sagirsiddique (1); venkatesh.a (2); Vinu_Answers (2)
