Previous in Forum: Corrosion Inhibitor   Next in Forum: Golden Welds
Ovality Tolerance Level
06/10/2011 11:56 PM
Dear Experts,
Please let me know the tolerance level of [FITTINGS] ELBOWS of 84" ASTM A 403 316/316L.Do tell me the standarad to refer and other relatyed details.
Good Answers: 70
Re: Ovality Tolerance Level
06/12/2011 12:53 AM
Click Here
06/12/2011 10:20 AM
Well said sir...............I like it.
06/12/2011 7:32 AM
dear sampath,
YOU WILL FIND THESE TOLERANCES ON THE FITTING DIMENSION CODE ( i.e : MSS), SEND ME THE DIMENSION CODE NAME AND I WILL HELP YOU SEARCHING.....
SALAM
QA/QC ENG: AMR SOLIMAN
06/15/2011 4:03 AM
Shhhhhhhhhhhhhhhhhhhh!
06/18/2011 8:55 AM
From specifications of ASTM A403, the related reference standards of MSS are located at Para. 2.3 MSS Standards:
MSS SP-25 Standard Marking System for Valves, Fittings, Flanges, and Unions
MSS SP-43 Standard Practice for Light Weight Stainless Steel Butt-Welding Fittings
MSS SP-79 Socket-Welding Reducer Inserts
MSS SP-95 Swage(d) Nipples and Bull Plugs
Notes:
1. I have a copy of both MSS SP-25 and MSS SP-95, and I guess that the ovality tolerances of elbows shall be located at MSS SP-43.
2. I got a copy of MSS SP-43, 5 min. ago, and found another type of elbows tolerances not including ovality with max. NPS 24 only.
06/17/2011 1:29 AM
This large size of elbows NPS 84 may be produced by fabrication at a mill/workshop, therefore -at least- we can apply the tolerances used in design and fabrication of pressure vessels -unless there is a certain code denotes for that tolerances used for elbows- as per ASME BPVC, Section VIII, Div. 1, Para. UG-80 "Permissible Out-of-Roundness for Cylindrical, Conical, and Spherical Shells":
a. At any cross section (including head-to-shell junctions): Dmax. - Dmin. ≤ 1 % D
b. When the cross section passes through an opening: Dmax. - Dmin. ≤ 2 % D
Where Dmax. = Max. inside diameter of shell,
Dmin. = Min. inside diameter of shell, and
D = Shell nominal diameter at the cross section under consideration
06/18/2011 3:31 AM
Mr.A.H.Galala
Thank You so much.
Register to Reply 7 comments
Abdel Halim Galala (2); dj95401 (1); met_3mr84 (1); MOBI (1); PWSlack (1); sampathkumar (1)
You might be interested in: Pipe Fittings, Hose Fittings, Conduit Fittings
