Previous in Forum: Shaft For The Roller   Next in Forum: Ovality Tolerance Level
Corrosion Inhibitor
06/10/2011 9:26 AM
Please help
I want to use Sodium Nitrate (99.3%) as a corossion inhibitor with hydrotest water pH - 7.33, Ca-2045mg/l, Mg-1216mg/l, Cl-11600mg/l, SO4-1284mg/l, CaC)3-10100mg/l. Please suggest the quantity of Sodium Nitrate required.
Pathfinder Tags: Corossion Inhibitor
Re: Corrosion Inhibitor
06/10/2011 10:47 AM
It would be better to use sodium nitrite and not the nitrate. Sodium nitrite is a reducing agent, an oxygen scavenger and a good corrosion inhibitor. Sodium nitrate ain't so good at it, as it doesn't react with oxygen.
Another way of inhibiting corrosion while carrying out the test is to get the pH above 8.5. Any alkali will do.
Without knowing the quantity of water to be dosed, it is a bit difficult to suggest the quantity of material required.
06/10/2011 1:29 PM
Thanks. Total water requirement works out to 26000m3. Please help me do the calculations.
06/10/2011 1:32 PM
Please suggest suitable alkali
Register to Reply 3 comments
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
