Previous in Forum: Residual Current   Next in Forum: Waste Water Treatment
22 comments
Designing Gas for Different Temperatures to Cut Costs
06/11/2011 1:17 PM
Is it possible to design a kerosine style gas product for use in really hot days of summer ,and the reason for doing so would be refining less costly gas, but only when its really hot outside, and then going back to a colder climate regular gasoline the rest of the year.Requiring a seperate tank and nozzle similar to Diesel fill-ups.
I dont know that much about kerosine but I know the grandparents did.ds
dsuzmay@gmail.com
Re: Designing gas for different temperatures to cut costs
06/11/2011 11:44 PM
Yes - you are absolutely right - your grandparents did know a lot about kerosene! The reason they did is that they all used kerosine on a regular basis as a replacement for gasoline. Tractors all ran on Kerosine for decades. It was after WWII when folks forgot to have common sense when Kerosine became the kludge that it is today.
I have a 1947 John Deere A that has two tanks on it. I am in the middle of restoration of it right now, and was actually thinking about this just two days ago. The front one (only about 2 gallons) is for gasoline and the cap was painted RED. The rear one (holds probably 10 gallons) was for the Kerosene and the cap is painted yellow. You start the tractor on Gasoline, then you work it and get it up to temperature (there is an adjustable shutter on the radiator to help do that quicker), then you switch it over to Kerosene. It will plow all day on a tank of Kerosene - maybe half that on a tank of gas.
The kicker here is that most of the farmers that currently own them have always ran the gas through the Kerosene tank, and many don't even know what Kerosene (fuel oil) is. Since I am taking mine apart, I got curious about how they go about making the switch-over, and it all goes through the same carburetor system. People were a lot smarter in those days than they are now - you can't get a flex-fuel vehicle these days that runs on half-priced fuel with better efficiency than the main fuel, and 85 years ago they did it without electronics.
I also have a 1932 Hart-Parr, and that also runs on Kerosene. If you run it too hard, it actually will ping and get hot spots. The cure - believe it or not, PURE WATER. If you run the water in the fuel mixture while it is running hard, the water will instantly turn to steam when it reaches the hot combustion chamber. Steam expands like 10,000 times the volume of water, so it actually helps out the combustion process and adds power! Again - we don't have that technology any more, either, so we just buy more dead dinosaurs to power our vehicles.
Imagine if you tried to get the public to buy in to starting a car on one fuel, running it for 5 miles, switching it over to Kerosene and running hard another 10 or so, then adjusting the MANUAL carburetor and bleeding in some water! You would get laughed right out the door. They would actually HAVE TO adjust the carburetor constantly and pay attention to the sound and behavior of their vehicle.
So to answer your question it is entirely possible. I don't know exactly how it works (I was born in the tail end of the '60s myself), so I plan on having a long discussion on it with my father who grew up running the Hart-Parr while we are working on the Deere. I would like to know more about the system, and perhaps figure out a way to adapt it to modern vehicles. I suspect one of the keys to making it work is the great big cylinders with huge compression and low RPMs that the older tractors have. I suppose that would not go over well with most car buyers, so it is probably a commercial failure, but it would be a fun project to play with and could save a bunch of money to switch a vehicle or two over in your stable of transportation.
06/12/2011 12:36 AM
Expansion of water to steam is something like 1700/1 at atmosperic pressure. If it were 10,000/1 I think that we we would be still using steam engines, that's a terrific ratio.
06/13/2011 2:13 PM
Sorry Rickwil - It was Sunday, and I was too busy relaxing to check the facts for sure. That was the reason for "something like, but I was off by a factor of 5 - My bad!
06/12/2011 11:52 AM
I gave you a GA for that, although as previously indicated, the 10,000:1 ratio for the expansion of liquid water to vapor is 5 or 6 times too high for atmospheric pressure, and 40-100 times too high for the pressures inside an engine, depending on the compression ratio. Still, even a 100:1 ratio is quite useful if the right amount of water is injected at the right time and place... It should be no big deal to modify the computers that already monitor many attributes of engines to incorporate water injection. I think I recall that there is an issue with water injection (besides additional complexity) - it may have had to do with nitrogen oxide generation...
To the OP: The answer, again as previously indicated, is clearly that it IS possible and is currently done, although not to reduce costs. On the other hand, depending on the volume produced and the location, it may be impractical and/or illegal. In the 1950's and early 60's, your eyes burned if you went to Los Angeles in the summer. There are way more cars now, but thanks to better (and therefore more expensive) fuel and better (and therefore more expensive) engines and emission systems, you can now go to LA and only have to worry about traffic!
06/12/2011 2:04 PM
Just this:1)There is a new trend in diesel engines,specially in large ones to add water perhaps with a separated injection in the same injector (Lorange (M.Benz division)),Mann and ..Mitsubishi? with their own and so differents systems.2)The gasoline quality could be increased by a "Vitameter":After years of research the result was (really was?) a higher quality gasoline (octane number)could be made in a cheaper way.3)Still today i guess,the most efficient engines are steam machines,but this is not related to the capability of water to expand.On the other hand you need 539 cal for each gram of water you convert in vapor (rounds 4.19 per joule).-
Good Answers: 74
06/13/2011 8:30 PM
GA
More should think like this and practice it. If you would only live next door I would come over and give you a hand with your restoration. Not that I could help much but learning, stealing with my eyes I could.
The steam engine has not seen its days and combining with other fuels is an old hat. I am on the case but the resources are so meager. Theory has never the full answer and with guys like you enthusiasm and fun are still part of it. This should give your dad a second wind too so good on Ya's.
All the best from here, Ky.
The Twain Has Met
08/10/2011 10:48 PM
thank you alas, i am not a guy
dsuzmay@gmail.com
Good Answers: 74
08/11/2011 12:52 AM
The Twain Has Met
08/12/2011 1:40 PM
'alas' is not the correct word! I, for one, welcome lasses here! I know I'm not alone...
Good Answers: 74
08/12/2011 4:29 PM
Same here dk. Just wondering about the context
The Twain Has Met
06/19/2011 9:28 PM
you have a john deere all fuel engine. It has a 4.5 to compression ratio, that is why it can run on kerosen as kerosene has an octane number of around 30.
As for better mileage or more work per gallon, BUNK. Kerosene might get you 15% better fuel economy on a gallon basis only because kerosene has that much more energy.
Re: Designing Gas for Different Temperatures to Cut Costs
06/12/2011 2:10 AM
I think gasoline and diesel are already tuned for summer/winter conditions; it seems a similar scheme should also work for kerosene.
Good Answers: 80
06/12/2011 12:24 PM
With today's controlled injection systems, it would be "almost" easy to produce a multiple fuel system. You could have tree tanks of separate fuels. The mixing would be controlled by the computer and the driver would not even know. Only fill up the thanks with the correct liquids. I hope that most people could handle that. Anyway, the pumps nozzles could be keyed to prevent mistakes.
Would it be more efficient? The idea of injecting a little water in the combustion mixture seems good since we have a surplus of heat that need to be evacuated. The problem might be incomplete combustion and increased pollution. I am certain that some experts have already looked into it a long time ago. They might have rejected the concept at the time because of various technological or political issues. With the increase in energy prices, the system might come out again.
As for using denser fuels, it is certainly possible but there might be problems with cold temperatures. We might need some pre-heating in some cases on simply run on lighter fuel in the winter.
As correctly stated above, while more efficient, this would not be acceptable if more pollution is produced.
06/13/2011 2:30 PM
I am in full agreement with the comments on emissions. You will never get it to fly with emissions issues, but I suspect that those could be overcome. Maybe a catalytic converter or something similar. The tractors built shortly after the turn of the century didn't have to worry about such things. Off-road equipment is even needing to worry about such things these days.
I am not sure where the economy is in abandoning all this old technology in the name of "green". I agree that we need to sustain our lives and protect the earth, but we don't all live in the Los Angeles valley, either. If you burn something more efficient for a shorter period (20% less), but it is 10% dirtier, are you REALLY polluting? Or is the "greener" fuel polluting? It is certainly more net pollution!
I am not saying Kerosene will be cleaner or even better, but I think we sometimes look at only PPM or percentages, and miss the big picture. I once had a Cadillac that got 24 mpg on the road, and it had NO emissions or modern technology. Now we have exotic metals, modern electronics, and emissions systems. Now I drive a Grand Am (1/2 the size and 1/3 the weight) and I can't seem to get 24 gpm. Is this really technology we need or would I be better off with a grand am that gets 50 to 100 gpm and is twice as stinky?
I know this is a tad off-topic, but I think it is a question we need to ask ourselves...
06/14/2011 1:07 AM
I see the most of the people here thinks the water injection increase the polution when in fact the companies are already using a complex tech to apply this with the only purpose to reduce contamination.Is not clear to me why adding water would improve the thermodynamic cycle.-
06/26/2011 12:20 PM
I think its the steam it must add a false degree of volume and thrust.ds
dsuzmay@gmail.com
06/26/2011 2:02 PM
Why do you say "a false degree of volume and thrust"?
The engine must be cooled one way or another! An appropriate amount of liquid water injected at an appropriate time in the cycle will indeed be converted to water vapor, producing a very real increase in pressure (thus thrust on the connecting rod), while absorbing heat (cooling the engine), thereby reducing the load on other cooling systems.
I understand this was standard procedure in WWII aircraft engines.
06/26/2011 7:25 PM
Just is not easy to see what you say because water takes a good part of remaining heat only to convert itself into low pressure steam so then you take care if you are not making a boiler instead an engine.2)A good part of this heat is very useful converting it in kinetic energy of exhaust gases which helps end faster the cycle to the next and increasing the engine power.3)Takes time imagine this cycle:Using a part of engine power to compress air and injecting :you don't need loss energy in latent heat of vapor but you do compressing enough to inject...Etc.Thermonynamics is complex, no so fast.-
Good Answers: 130
06/26/2011 7:40 PM
I've just skimmed, so apologies if this is a repeat of someone/s.
Have a read of this
But the last time I purchased, kerosene was more expensive per liter than ULP and Diesel.
(but I guess that could be a function of the tax system)
06/27/2011 11:01 AM
Still remains a lot of engines manufactured to work with normal gasoline or kerosene.Best performance you got is using fuels designed specially for some type of engine.Commonly diesel fuel is more expensive to obtain than gasoline but if you respect the production costs the gasoline were completely spent and nobody would buy or even develop any diesel engine:diesel fuels or oils would be undesirable garbage.Gas (liquefied or natural) are cheapest: if you respect thats costs in the market don't remains pressure in the wel to extract the petrol.-
06/26/2011 8:39 PM
That is why I said "an appropriate amount" of water. I don't know how much is appropriate, but it is a very small amount.
Here is one pretty good article.
06/27/2011 10:45 AM
Uphere in 6 and 10 i've mentioned:1)Vitameter (thats not the only name for it) for gasoline engines 'history,google on you will enjoy!;2)Incredible technology from the most important diesel injection systems from Germany:L'Orange manufactures large injectors for large engines with two sets of holes in the tip of injector!!One of those are for water injection!! look inside their website.Are available pdf's from MAN too about water injection and fuel post injection,experimental results;3)Most people doesn't know the true diesel engines are not manufactured anymore just the name is used today.Those engines had a big compressed air bottle or tank what pushed the fuel into the combustion chamber at same pressure than the end of compression stroke:analize what happens if you keep injecting air (with its "expansion power")after the atomized fuel+air,if they did or they didn't.-
Register to Reply 22 comments
34point5 (1); dkwarner (4); ds (2); ferquiza (5); Frank Designs (3); ky (3); marcot (1); rickwil (1); Tornado (1); vicini (1)
