Previous in Forum: Lighting Calculations in Tunnel   Next in Forum: HV EE Project
9 comments
Distribution of Construction Power on OHL
06/13/2011 8:16 AM
20 MW power has to be distributed throughout the project location. It is proposed to have 33kV over head lines to serve this purposes as the loads distances are 3 Km away from the generating source. The power is supplied by DG sets. Now i need to design the 33kV overhead line for the successful distribution of this constructional power from the DG house to the loads. I appreciate any help in this regard thank you.
Creativity guaranteed!!!!!
Re: Distribution of construction power on OHL
06/13/2011 8:21 AM
It would be inappropriate to tackle such a task without having received a locally-satisfactory level of training. To request such training and advice via a global internet forum with anonymous subscribers is preposterous. Apply for training within the organisation that has generated the task.
06/14/2011 12:25 AM
I just want to have discussion over that. The preliminary training has been given to me and the initial design is also made. Now deciding the transmission is the present task.
06/14/2011 3:49 AM
Then hire someone who can do the work.
06/14/2011 4:02 AM
Thank You.
Good Answers: 170
06/14/2011 5:20 AM
Calculate the current to be transmitted; find from a good overhead line (ACSR) catalogue, which is the nearest size conductor for your purpose; have the requisite inter-phase & phase-to-earth clearances, calculate sag, decide on the span of the OH line supports, calculate voltage drop, follow local regulations regarding transmission thro OH lines.
India - Member - New Member
06/14/2011 8:38 AM
Dear sash46,
If you wish to start discussion, all interested to participate should be convinced that it is serious one.
Will you mind sharing your preliminary design detail for 33KV, 20 MW line you made.
When was last time you did something for first time.
06/14/2011 9:06 AM
Thank you. But i fear i may not share those as it is the company's property and i need to take permission of my superiors.
06/14/2011 9:07 AM
Btw could you please tell me what all are required.
Re: Distribution of Construction Power on OHL
06/14/2011 5:49 AM
Thank you electricalexpert65
My main doubts are
1.Does the transmission line guidelines of EHV be applied to this?
2.How to decide the span?
3.I am getting weird results in the sag calculations.(the area is hilly terrain and has inclined span major of the time).
Register to Reply 9 comments
electricalexpert65 (1); Happy singh (1); PWSlack (2); sash46 (5)
