Previous in Forum: SMPS   Next in Forum: Hazardous Area Classification
Regarding to the Level Gauge
06/13/2011 11:50 PM
What's ur opinion on the importance of boiler drum level gauges? And which kind is more accurate? DP transmitter? electrode indicator? bi-color level gauge? or the magnetic level gauge? And how to conquer the deviration which caused by different enviornments inside and outside the boiler drum?
Pathfinder Tags: level gauges
Re: Regarding to the level gauge
06/14/2011 3:52 AM
The importance of the level gauge is to make sure there is always sufficient water above the firebox crown so that the fusible plug doesn't melt.
Re: Regarding to the Level Gauge
06/14/2011 11:30 AM
DP transmitter is accurate but you are asking about level Guages EDLI (electronic drum level indicator) it is reliable but not much as DP transmitter Coming ti bi color leve guages not working properly and ihope this may help you
06/14/2011 9:31 PM
Thanks, Puru. But u see, most power plants have at least two or three principles of level measurement instrument.
And most of the measurement instruments are outside the boiler drum. It is influenced by the outside enviorment. And don't you think it's harmful for the measurement result. Luckily, Our company develops a new range of level gauges which can conquer the problem. And we have also applied the patent.
And now, we are enlarging the market share. If you and your friends need this kind of product, please contact us. And I am looking forward to your favor.
Register to Reply 3 comments
Jessie Liu (1); purusotham4ugmail.com (1); PWSlack (1)
You might be interested in: Drum Pulleys, Drum Heaters, Level Sensors
