Previous in Forum: Hydraulic Thrust in Hydro Generators   Next in Forum: PF Fineness Problem
Plastic Flamability Related Discussion
06/14/2011 2:37 PM
Hello,
I know that under UL94, we different flamability ratings like H-B, V-0, V-1, V-2 etc,.
There are several websites explaining each of these. But, I could not find a good resource to explain which rating to go to.
There is little diference between each of these ratings. For a speific case, Say I am using a V-0 material, but in reality may be a V-1 or V-2 might work too.
So, I am looking for a good resource to learn which applications demands V-0 and Which one V-2 ....
Do any of you come across such a reference.
Thanks
C1
Re: Plastic Flamability Related Discussion
06/14/2011 2:59 PM
UL94 is a test, not a specification. Underwriters Laboratories is a testing organization. They do not establish how much protection you need. They only tell you if your product meets their test standard.
It's up the the designer to establish flammability requirements.
06/14/2011 3:39 PM
My application probably might work OK even if its H-B rated. But I dont know why the previous engineer has used a V-0 material. Its very expensive, to make it cheaper, I could use H-B insted.
Anyways, on the other hand, do you have any material explaining what conditions demand use of V-0, V-1 or H-B?
06/14/2011 7:02 PM
No, it depends too much on what industry it is and what the product is. One size doesn't fit all.
Every industry has its own requirements. Something in orbit won't burn, because there's no air. But, electronics overheat in orbit, because there's no air. What are you building?
http://www.ides.com/property_descriptions/IEC60695-11-10.asp
06/14/2011 7:25 PM
I am building a optically clear, sealing cover over a high power LED board in a street light application. There could be max of 200 deg c temp involved. Exposed to sun in out doors. I can provide any other info if needed. This fixture would need to be UL listed. I don't know if this would really need a V-0 rated material to be used. Thanks c1
06/14/2011 7:42 PM
As someone who deals with a municipality every day, I'd say you need the V-0 rating.
Not necessarily because another rating would not work, but because chances are whoever is buying the lights doesn't have sufficient knowledge to make an informed decision.
Live with it.
