Previous in Forum: DIY Plastic Extruder   Next in Forum: Re-Paint to White Over Powder Coat Blue
Weld Design
06/19/2011 9:02 AM
Hi All,
Please guide me In Double V groove edge preparation 60° groove for pressure vessel may be made at both side or may 1/3 & 2/3 and what is the tolerance in degree as per which code (is it mentioned in ASME Section 8 Div 1)
Regards,
Anil
Anil
Re: Weld Design
06/19/2011 4:55 PM
If memory serves, the angular tolerances are ±2°, but they are not all that easy to measure from such small distances, especially if manually ground in the field.
V grooves are generally 75° included angle (37.5° on each part); J grooves are more likely to be 60°.
Your company should invest in a copy of the ASME standards, if they intend to manufacture accordingly. Individual employees should not be expected to shell out that much money.
Good Answers: 34
Re: Weld Design
06/20/2011 4:23 AM
Wich Thinkness, Please.
Re: Weld Design
07/11/2011 9:06 AM
for 63mm thickness.
Anil
Re: Weld Design
06/20/2011 7:15 AM
Free download Fits and Tolerances used in both Fillet and Butt welds: Fits & Tolerances.
Register to Reply 4 comments
Abdel Halim Galala (1); akp_lmp (1); Tornado (1); Whitephone (1)
