Previous in Forum: An Instrument That Stops Rotating Gives Shutdown Command To Machine   Next in Forum: Transistor
21 comments
Making a Battery for a Laptop?
06/20/2011 12:08 AM
Is it possible to create a replacement battery for a laptop using rechargeable triple A batteries? One month after the year long warranty expired the four cell battery died despite always being charged and I would just assume buy a new laptop then pay $150 for a new battery hence this question from someone who is not electrically inclined but capable of learning new tricks:
I have a Dell Inspirion 1545 running Vista with a Intel Celeron CPU 900 at 2 point 2 Ghz
The computer isn't worth investing any money in for numerous reasons and not having a battery is the final straw-
All we want are the facts, ma’am.” Sgt Joe Friday, "Dragnet"
Re: Making a battery for a laptop?
06/20/2011 12:23 AM
06/20/2011 3:24 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
06/20/2011 7:11 AM
Lithium battery is fussy about charging, if overcharged, may catch fire. Laptop has quite elaborate circuitry to prevent overcharging, this circuitry may not work with your battery. So if you use your battery and at the same time , plug in AC supply ,it may be very dangerous.
My advice is, play with something else.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Good Answers: 119
Re: Making a Battery for a Laptop?
06/20/2011 9:26 AM
You "could" make a battery out of AAA NiMH batteries that would power your laptop, but it would be large, expensive, difficult to assemble (for reliable operation), and your laptop's internal battery charging circuitry would be confused/unhappy because it is designed to safely monitor and charge a lithium battery pack. It is important to know that laptop lithium battery packs contain a small microprocessor that protects, monitors, remembers, and can communicate the battery status and charge/discharge history of each cell in the pack. This is necessary for best performance and safety.
Typical laptop battery packs contain about 50 [W-Hr] of stored energy. An equivalent NiMH pack would require ~40 AAA rechargeable cells. Cost for the cells seems to be around $50. Adding the materials to assemble the pack and build your own custom recharging circuit would make this project too complex and expensive.
Replacing the lithium cells alone can work and be a cost effective solution IF you have some basic mechanical and electronics skills. Be aware that the smart circuitry usually has a ONE-TIME short circuit protection fuse. If you accidentally blow this fuse, you may have to scrap the whole circuit.
I just found dozens of listings around $30 on Ebay for a direct replacement of your laptop battery. Over the last 10 years I have ordered many laptop batteries (for myself, family, friends, and co-workers) from Ebay sources and have not had any problems yet.
I strongly suggest you drop the home-made battery pack project and find/order a clone (non-DELL) replacement battery.
Good luck!
06/20/2011 9:56 AM
Ebay it is! Case closed!!!!
06/20/2011 10:45 AM
Wise choice.
You will find that advice given by mjb1962853 is usually top notch.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
06/20/2011 10:33 PM
Would it be wrong or Grammar Police, to point out to the OP that the phrase is "...I would just as soon buy a new laptop..."
Not "...I would just assume, buy a new laptop..." ?
OP is clearly American. I think I would like to know, if it was me. It reminds me of the guy talking about his French benefits at work... instead of his fringe benefits.
Just sayin'...
06/20/2011 10:48 PM
If he meant "I had rather buy a new laptop" (I had just as soon) and not "I just assume, buy a new laptop"(I think, buy a new", you could be correct.
So much depends on context.
I'd stand down the "Grammar Police", for now.
Good Answers: 39
06/20/2011 11:16 PM
Ah, yes. True. That could potentially be a tricky one, depending on context.
Standing down.
I do kinda like the French benefits though!
06/20/2011 11:32 PM
Blue prince has always been my favorite.
Good Answers: 39
06/20/2011 11:38 PM
And finger prince, too!
Soo... if a frog is walking across the mud, does he leave frog prince behind him?
Good Answers: 110
06/21/2011 11:47 AM
We used to sing, while waiting for documents from the vault: "Someday, my prince will come."
Think big. Drive small.
06/20/2011 11:18 PM
Agreed however feel free to give the "I've got entirely too much time on my hands Police" a call anytime you want.
Have you tried turning it off and on?
06/21/2011 12:05 AM
Several points:
1. All current laptops I'm familiar with use intelligent batteries. That is, the battery is not just a group of cells. It also contains devices for determining the condition of the cells and signalling that information to the laptop. A successful replacement must include that additional circuitry.
2. As previous posters have said, it is dangerous to attempt this. There is a significant danger of either causing a fire, or destroying the laptop.
3. I haven't checked your specific model, but I seriously doubt if the current battery is 'four cell'. Most current laptops have supply voltages in the 12-24V range, while a four cell battery has something under 6 Volts, depending on the battery chemistry.
4. Unless this computer has been physically abused, it is certainly economical to buy a new battery. Apparently you have other reasons for dissatisfaction ...?
5. I understand you to say it has always been charged. That may be the reason for the problem. Laptop batteries need to be used! Leaving it plugged in all the time without ever discharging the battery will cause premature failure.
6. I assume the one year warranty you refer to was the battery warranty, not the computer warranty. Original computer batteries should last at least a couple of years. This laptop is still doing fairly well on its second battery (not the original manufacturer's battery) after almost 4 1/2 years.
06/21/2011 12:30 AM
Lyn and out of the box experience.
Do you guys love each other or something weird like that or what?
Too much time on your hands, for sure ... it must get a bit lonely down there in
Arizona.
Get a private chat room and spare the rest of us the pain please.
biggiginthesky
Good Answers: 39
06/21/2011 1:18 AM
Ahh... if I could only think of an appropriate quote about irony..........
06/21/2011 12:25 PM
You seem to have developed quite an erection for me, with 3 of your last 5 posts devoted to nothing constructive at all, except trashing me.
I truly hope that I did something to incite you, but I'll be jiggered if I can figure it out.
If you don't mind, you might share it with us so we all don't think that you are just a psychopath with a random hatred psychosis.
In the mean time, feel free to continue your attacks on me, if they take the abuse off of someone you come in contact with every day like your children, if you have any.
06/21/2011 8:54 AM
Well if you wanted to "kludge" something to just make it work, you could get a small gel cell battery and a small DC to AC inverter hook them up and just plug your ac plug into the inverter.
06/21/2011 9:33 AM
GA. Not very efficient, but definitely the safe way to do it! I use my laptop in the car that way fairly often, using the car battery of course. That way you know you have the correct voltage and polarity for the laptop.
BTW OP, if the battery gets really bad, you should remove it entirely. I've seen several cases of bad batteries preventing the computer from working. Of course it is less portable without the battery, but it sounds like you weren't using it much as a portable anyway.
Ireland - Member - Aging Gracefully Member
06/21/2011 10:30 AM
I think the amount of time you spend working on this would be significant in cost and instead you could go to http://www.sparepartswarehouse.com/, a place I have bought all my Toshiba accessories, replacements etc. It's the best price I have found online and no, I have no disclaimers here except that I am a customer of theirs and have spent about $100 there over the last few years.
waidesworld
06/21/2011 3:21 PM
If you need to ask here, you don't have the specialist knowledge to make a GOOD working battery. Buy a new one.
The reasons that your battery is dead is because you have charged it too often. Good batteries handle around 200 re-charges, bad ones less, far less!!
Good tip, let the battery run down till about 10% of charge, remove from laptop and store, only charge it when you need to go off grid.
Storing the battery fully charged is bad.
Every time you plug your laptop in to the mains is bad for the battery and is counted as a charge, even when the battery is full.
I have Laptop batteries that are over 10 years old, this laptop's battery is 5 years old, has hardly been used......only where no mains was available.
Register to Reply 21 comments
Andy Germany (1); bht2010 (1); biggiginthesky (1); bravo88 (1); dkwarner (2); K_Fry (1); lyn (5); mjb1962853 (1); Out of Box Experience (4); sbruel (1); stpipefitting (1); Tom_Consulting (1); Waidesworld (1)
