Previous in Forum: Motor Reversing Cause   Next in Forum: 1 Phase Miss
Cable Gland
06/20/2011 12:14 PM
Hello dear,s,
is there anybody who can tell me that for how much cable size, we used what size of cable gland and what will b the whole size.
Foe example.
Cable size 50 mm.
Cable gland?
whole size for that gland?
is ther any formula please send me.
Thank,s and Regard,s.
Muhammed Ikram Shehzad.
Ikram Shehzad
Re: Cable Gland
06/20/2011 2:35 PM
Check with manufacturer web site. what do you require? whole size or hole size?
Re: Cable Gland
06/22/2011 3:50 PM
sorry dear not whole size. it is hole size.
Ikram Shehzad
Re: Cable Gland
06/21/2011 3:08 AM
There are two relevant numbers: the o.d. of the cable that the gland must grip, and the (larger) diameter of the the aperture into the panel or junction box into which the gland is inserted. In the United States, the aperture into the panel/box corresponds to a standard pipe size. To pick an example, say 1-inch pipe size = 1.315 inch diameter. This would accommodate cable sizes up to about 1-inch o.d. (Smaller cable would use compressible elastomer bushings of correspondingly smaller i.d.)
Good Answers: 170
Re: Cable Gland
06/21/2011 10:10 AM
Is it a single compression gland or a double compression gland or a flange type (Siemens) gland? Gland manufacturers give a reday reckoner for choosing any of the above glands for any given type & size of cable. Try googling Comet Cable Glands.
Location: off the beaten track, not quite whoop whoop nor humptydoo
Re: Cable Gland
06/27/2011 10:54 PM
Making some assumptions... 50mm cross sectional area and single core, could be 11mm diameter for pvc insulated, 13.7mm for single core double insulated (SDI). Let us just run with between 10 and 14mm... standard nylon cable gland of 20mm hole size will accommodate cable diameter between 10 - 14mm, unarmoured metal gland of 20mm hole size will accommodate 9 - 13mm cable diameter.
check cable outside diameter, and then check gland specs - most cable manufacturers have downloadable catalogues (such as OLEX), and wholesalers should be able to provide parts catalogues so you can give them part numbers when ordering (cause they are lazy and want you to look it up for them)
Everything works out in the end, just not neccessarily how you want
Chook (1); electricalexpert65 (1); ikram shehzad (1); pravinba (1); Tornado (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
