Previous in Forum: Spiral Wound Gasket Flanged Joint Tightness   Next in Forum: Conveyor Chain
Ligament Efficiency
06/20/2011 10:44 PM
Dear all,
Please explain for me the term of "ligament efficiency" in heat transfer field.
Thanks!
Re: Ligament Efficiency
06/20/2011 11:53 PM
In the tubesheet of a heat exchanger, the narrow pieces of metal between the tube holes are called "ligaments." The thickness of the tubesheet resists pressure within the shell of the heat exchanger. The "ligament efficiency" is a comparison of this pressure resisting ability with that of a solid plate without such holes. You may find more info about this from TEMA (Tubular Exchanger Manufacturers' Association) than from ASME. (I'm not sure about this, having been out of the field for quite a while.)
