Previous in Forum: Dyn11 vs Dyn5   Next in Forum: Droop of a Generator
Motors and Controllers Price Range..
06/21/2011 12:01 AM
I've been looking for 100watts -300 watt range of motors and controllers, DC or AC, and the price ranges are rediculous. I saw this 1/18th HP motor with control, for $700, meanwhile I bought a milling machine that costs $600 for the whole thing, it has a 3/4hp Motor with speed control plus 130 pounds of machine. I bought a potentiometer for a few bucks, and used a car battery charger for a power supply to power a 135 watt motor that costs 50 bucks.
Re: Motors and controllers price range..
06/21/2011 1:46 AM
What sort of control are you actually looking for? Precise speed or positioning? If so, that may be fairly sophisticated, and thus expensive.
Good Answers: 119
06/21/2011 5:47 AM
You should search Ebay. I've purchased many used and new variable speed AC drives (1-3 phase in, 3 phase out) and DC motor drives up to 3HP ratings. All of them were well under $100 and all of them were 100% functional.
Just saw (4) 1/4HP AC drives sell for ~$80 (140563101207). That's $20 for each drive.
Specs were:
Input ,1-ph, 120V, 6A
Output, 3-ph, 0-240V, 0.25 HP, 1.6A, 0-400 Hz
You would need something a little larger for a 3/4 HP mill (I suggest 1 HP). If you use the right search criteria and wait patiently, you could get one for ~$50. IF you are willing to pay ~$100, you should be able to get one almost immediately. Best wishes.
06/21/2011 3:05 PM
monsterscooterparts.com has some good motors in their recreational scooter section. probotix.com and kelinginc.net seem to have good controllers which can be used for automation, I think.
Good Answers: 12
Re: Motors and Controllers Price Range..
06/22/2011 12:30 AM
Try using automobile motors like: Wiper motor or power steering motor; these must be cheap due to huge volume manufacturing.
Subramanyam
06/22/2011 2:07 PM
Here's a source for time delay relays, and power supplies. factorymation.com
PC power supplies are also good, (mass produced) but for the trouble of bunching the wires maybe not.
I used a corded drill and a C clamp to hold the trigger at the speed I wanted it. Motor, power supply, speed controler ~$60
06/22/2011 1:57 PM
guds777
Register to Reply 6 comments
buzneg (2); guds777 (1); kvsubramanyam (1); mjb1962853 (1); Tornado (1)
