Previous in Forum: Suitable Starter for Ball Mill Starting Through Slipring Motor 11 kV 2600 kW   Next in Forum: GE Model 11 Gas Detector Relay
13 comments
Explosion Proof Motors with Internal Temp Cutoff?
06/23/2011 8:42 AM
I am swapping motors in an existing plant built in the 60's. There are a bunch of motors which have temp switches internally wired to high temp shutoff relays in the motor connection head.
Has anyone seen one of these recently? Any manufacturers make them? The starters and existing conduit runs don't have a PTC / Temp Switch cable to run back to the starters.
My motor supplier doesn't seem to help. Any leads would be helpful.
Pathfinder Tags: Explosion Proof motor safety XP
Re: Explosion Proof Motors with Internal Temp Cutoff?
06/23/2011 9:43 AM
It is more common of late to contruct a motor with (a) temperature device(s) embedded in the windings, and to run a cable from it/them to the motor starter cubicle to carry out the control functions there.
The difficulties of changing-out heritage motors that are configured differently are appreciated.
06/23/2011 10:27 AM
Yes, this it the way we would build new plants.
Baldor has the internal high temp disconnect in the motor connection head but only up to 1 1/2 hp. I need 2 and 3 hp motors.
Good Answers: 117
06/24/2011 1:37 AM
I remember seeing these in the mid 70's, these days motors have temp probes connected to relays that shut down the motor at the MCC.
As a suggestion which you have realised I guess, that new motors and that extra bit of control cabling is now required to have new motors with temp protection.
It is unusual to have Ex motors with moving internal contacts/relays these days.
Good Answers: 181
06/24/2011 5:07 AM
I think it boils down to your going to have to run a new control cable to the motor for whatever type of temperature sensor you decide to use.
I've never come across FLP motors with internal disconnects, but the motors I worked on were a lot bigger
06/24/2011 6:43 AM
Dear Sir,
Such totally enclosed flameproof motors 550 volt, 120 KW were being used by
me in early 1973 to 1976. Motors were Russian make heavy duty,water cooled
with temperature sensor inside windings with tripping relay like relay contacts
in a FLOAT switch. Relay had gone defective sometime in 1974. It had to be
bypassed as there was no alternative. But motor was running very effectively.
At that time motor was dissambled and rotor & windings were looking like a NEW
Motor. If necessary motor can be used by convinient temperature sensors and
taking out control cable outside to starter panel.
Just for acedemic interest these heritage motors may be saved.
06/24/2011 8:25 AM
Yes, I can add a temp sensor to the motor case and high temp interlock, but will it be considered "safe", as safe as a new UL / FM approved motor?
I install temp sensors and interlocks all the time, but is there anything else which makes it meet code other than the "nameplate"?
Good Answers: 117
06/24/2011 1:47 PM
you should be able to get an EX motor with the temp probe fitted in the stator, that would be more in line with the code rather than a DIY job of fitting the temp probe and trying to retro-fit the correct Ex junction box etc for the probe terminations.
The pre-fitted probe terminations would then be in the motor terminal junction box, all you need to do, as TonyS suggested, is install the correct type of cable plus EX glands for motor power and an additional Ex gland on your temp feedback cable to your MCC.
Yes, you have to run another cable, but as I see it there is no other option, not these days. Better safe than sorry!!
Good Answers: 181
06/24/2011 1:55 PM
Any modification to the motor negates the FLP certificate!
Good Answers: 117
06/24/2011 4:14 PM
I wasn't suggesting that he makes any mods, the probe should be fitted to the stator, the terminations should be in the terminal box, and the knock outs for the temp probe cable should be there. What I did say was DO NOT attempt to modify it...
Good Answers: 181
06/24/2011 1:33 PM
The main thing is that the cable and glanding meet FLP requirements. If it doesn't the whole thing is invalid.
06/25/2011 12:08 AM
Agreed with comments of Mr. Tony S. FLP features,cable glands and terminal cover gaps should not be disturbed. Then it's ok.But why the temperature disconnect inside the motor required when it can be conviniently tripped from the starter.
Good Answers: 117
06/25/2011 2:55 AM
If you read the original posting, its and OLD motor built to a design standard no longer with us, the OP want to replace these old motor and still wants to keep the thermal protection, which you already know. Thats how and why the thermal trip is inside the motor, not as todays modern motor's, with the trips located remotely.
06/25/2011 3:59 AM
Thank you Brich. Heritage motors must be kept intact till it is possible.
Register to Reply 13 comments
A K BILLORE (3); brich (4); PWSlack (1); slandau (2); TonyS (3)
