Previous in Forum: Numbers are Missing in the Digital Clock   Next in Forum: Transformer
Power Quality, Voltage, Current Monitoring Portable Instruments
06/24/2011 10:34 AM
Looking for some suggestions for equipment to rent to monitor 3phase measurements on wind turbine LVMD components. Ease of use, 1-2 hr measurement storage capacity (per turbine) are some of the main criteria
Re: Power Quality, voltage, current monitoring portable instruments
06/24/2011 10:45 AM
What country?
06/24/2011 10:48 AM
USA, southern California.
Good Answers: 58
06/24/2011 11:29 AM
I did a Google search of "electrical test equipment rental in southern California" and received 2,590,00 hits!
Try this link
Good Answers: 131
06/24/2011 12:32 PM
ElectroRent is one that showed up in KJK's Google search, and which I have used in the past. They have been around for a long time and have good equipment. They have a variety of power measurement instruments available. Check them out.
http://www.electrorent.com/products/search/Power_Analysis_Recorders_Loggers.aspx
Good Answers: 80
Re: Power Quality, Voltage, Current Monitoring Portable Instruments
06/25/2011 10:35 AM
Don't get the small portable Hioki power meter. It cannot save the harmonics and power factor even if it measures them. It only saves waveforms. The fix memory is not enough. I have been much better served by its big brother with the removable PC memory card.
KJK/USA (1); marcot (1); PeterT (1); PWSlack (1); rdombek77 (1)
