Previous in Forum: How Do I Transform 110V To 130V   Next in Forum: Generator Selection Criteria
Current Density
06/26/2011 3:29 AM
The current density changewith the frequency, but does anyone have a table with recommended current densities as a function of the frequency?
Good Answers: 53
Re: Current density
06/26/2011 3:56 AM
Re: Current density
06/26/2011 4:58 AM
Thank you very much for your answer, your help is appreciated.
I know that current density is limit for the skin effect but would be helpful to have a table that tells me the current density as a function of frequency, such as:
For example Cu:
Diametre of cable Frequency Current density
0,1mm 1kHz to 100Khz > 8A/mm2
0,1mm 100Khz to 1Mhz > 6A/mm2
Have you got any kind of this table?
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Current Density
06/27/2011 6:28 AM
Current density may increase at high frequencies because the total conducting region in a wire becomes confined near its surface, This is also called skin effect. If the wire is carrying high frequency currents, depending on its diameter, the skin effect may affect the distribution of the current across the section by concentrating the current on the surface of the conductor.
Above graph shows Skin depth vs. frequency for some materials, red vertical line denotes 50 Hz frequency.
Vinu_answers Sure_Answers
Sure Answers Always
Register to Reply 3 comments
j.andrade (1); rakesh_semwal (1); Vinu_Answers (1)
