Previous in Forum: Grouting Material or Solution for Post Tensioning of Anchors   Next in Forum: Concrete Paving Blocks
8000 psi
06/27/2011 5:42 PM
hello every one i need to know something i want to know if i had a tail lift of a truck thats capable of lifting 2 ton weight what psi would it produce if its was pressing down on something
Re: 8000 psi
06/27/2011 5:50 PM
The amount of pressure in PSI depends on the total contact area.
Most tail lifts are made to lift, not "press down on something".
The "8,000 psi" and the "two ton weight" are meaningless in this context.
Re: 8000 psi
06/27/2011 7:11 PM
OK,
This question has many answers, yes? Depending how the listener hears it?
If you have a lift that can lift 2 tons (4,000#) and want to know how to produce 8,000 PSI of down force, you'd need a 1/2 inch of contact area. That's assuming the lift produces as much down force as "up force", which I doubt. Most are gravity down, I would think, for safety.
Re: 8000 psi
06/27/2011 9:45 PM
4000 ÷ area which is being pressed.
Re: 8000 psi
06/28/2011 2:45 PM
area of which being pressed would 8 inch square about the sizes as a concrete paving block to be excact each ram would be connected to 8 inch plate and pressing into a mold to compact the cement would it work what do you think all suggestion will help
Re: 8000 psi
06/28/2011 4:34 PM
4000 ÷ 64 = 62.5 psi.
I haven't heard before of compacting concrete by putting weight or pressure on it, but I think vibration methods can "float out" any entrained air in the mix.
Re: 8000 psi
06/28/2011 4:55 PM
if you goggle block paving machine you will see what i mean
Re: 8000 psi
06/28/2011 5:09 PM
It seems to me the limit of downforce of some portable machine would be it's own weight...
So, if I wanted 8,000 psi (eight thousand pounds per square inch), I would concentrate the 4 ton weight of the machine on a one inch square pad.
Or, did I miss something in the description?
[edit] I went back and read it all again... I don't have any idea where the numbers should be. Is this device portable? How much does it weigh?
Register to Reply 7 comments
Doorman (1); lyn (2); shaun1733 (2); Tornado (2)
