Previous in Forum: MGF Feed pump   Next in Forum: Max. sustained operating pressure
Sparge Steam
06/28/2011 4:36 AM
Dear sirs,
Please explain for me about funtion of sparge steam line connected to hotwell of steam condenser. Normally, what is the source of this steam?
Thanks!
Re: Sparge steam
06/28/2011 5:33 AM
Keeping the hotwell hot drives off any dissolved gases in the hot well contents. Dissolved oxygen can contribute to boiler corrosion. It is cheaper to raise the temperature of the water than to replace components in the boiler, with the attendant down-time.
The source of the steam is the boiler itself.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Sparge steam
06/28/2011 1:01 PM
PW has it right. The only thing I would add is that there are designs that extract a small portion of steam from the turbine as a source (which did originally come from the boiler). This regeneration technique can significantly improve the overall plant efficiency.
Sometimes my thoughts are in a degree of order so high even I don't get it...
Register to Reply 2 comments
