Previous in Forum: Dispense Items   Next in Forum: Flow meters in scada
12 comments
Box Valve
06/29/2011 12:13 AM
Hello all... I am working in Vietnam for Water treatment plant & has come across an item called "Box valve". We have never used this valve in India and unable to find any supplier. The box valve shall be used for draining the chamber .... Pl tell if u hv any info abt this equipment...
Re: Box valve
06/29/2011 12:30 AM
Maybe it's a valve box. That's where valves go.
Re: Box valve
06/29/2011 12:34 AM
I couldn't find any "box valve" either, but it might be another term for "knife valve", which sometimes has a rectangular shape.
Re: Box valve
06/29/2011 1:24 AM
no guys.. it is box valve( frustrating!!!) but unfortunately no specs are mentioned in the contract either.... this valve shall b buried underground as per the drawing....
Re: Box valve
06/29/2011 2:03 AM
This makes me think that Lyn is right, and that the specifier really means a valve box. Remember that this is Viet Nam, and the French language legacy may place adjectives after the nouns they modify.
Good Answers: 34
Re: Box valve
06/29/2011 5:48 AM
Good Answers: 34
Re: Box valve
06/29/2011 5:58 AM
Re: Box valve
06/30/2011 2:52 AM
Prasson,
Interesting device. I found this link with a reference to Box valve on a cornet [trumpet]. http://www.flickr.com/photos/gordonmedley/3158449414/
It does look like box-shaped. I am water treatment plant(s) you mention in Vietnam. Do you have any details? - BJInvention
"Keep on keeping on"
Re: Box valve
06/30/2011 2:57 AM
Prasoon,
I meant I am interested finding out about Water Treament plants in Vietnam, India, etc. BJInvention.
Re: Box Valve
06/30/2011 2:56 AM
In fact I was reading history of "horns", in which I came across this word. Box valve is used in horns.
Part of content of history is as below:
"This slender piston-type valve had some inherent acoustic problems. For example, the bore of the instrument, disrupted at the 90-degree bend in the windway at the bottom of the valve casing, was then further disrupted in the middle air passage of the valve. In addition, as the air entered the bottom of at least one piston, the valves could push air back at the performer when depressed, creating undesirable back pressure. Valves of this design were also difficult to disassemble.
The valve described in the original 1818 patent of Stölzel and Blühmel is known as the box valve. See figures 3 and 4. Blühmel developed this design in 1817/18 [Heyde, ibid, 22]. Acoustically, this design is theoretically far superior to the Stölzel valve as it avoids sharp bends in the windway, disruptions in the bore, and potential back pressure, but due to its square shape the box valve was undoubtedly difficult to construct and maintain. The box valve was probably applied to only a few horns."
Sorry I am not able to attache the sketches/image of box valve but you can get this detail at link as below:
http://www.public.asu.edu/~jqerics/earlval.htm
Re: Box Valve
06/30/2011 4:46 PM
What I know of a valve box is actually an access at grade that you use a curb key (handle that turns the valve like an extension) these are cylinders not sure where the term box came from but thats what they call them
Re: Box Valve
06/30/2011 4:50 PM
http://www.ejiw.com/valve-boxes-64/
Re: Box Valve
06/30/2011 10:00 PM
equivalant indian company who can supply similar things
http://www.govindsteel.com/Valve_Boxes_Valve_Box_Risers.html
Register to Reply 12 comments
BJInvention (2); lyn (1); Mukesh0861 (2); pipeit (2); PRASOON (1); Tornado (2); Whitephone (2)
