Previous in Forum: Why Would the 1st Stage Compressor Sweat and Foam Oil with 15deg Superheat?   Next in Forum: ASME B31.1 Steam Piping
Boiler Drum Size for Different Pressures and Capacities
06/29/2011 1:11 PM
What are the deciding Criterion for the Boiler Drum Capacity for different Pressures and Capacities of a Steam Boiler.?
Is it linked to Percentage of Capacity or Time or Pressure.? When the Pressure of Steam goes up, for a given Size of Drum and Capacity - the Sp. Vol. of Steam comes downn and for the given size of the drum - it can hold more steam.
If the Capacity goes up - for the given size of the drum, and pressure the quantity of steam in the drum comes down in relation to the capacity.
I request CR4 members to share their views and knowledge.
Thanks,
RAJESWARI.
Re: Boiler Drum Size for Different Pressures and Capacities
06/30/2011 5:38 AM
It's linked to steam production rate. This figure determines the heating surface area. The rest is a compromise.
06/30/2011 6:08 AM
Thank You Mr. Slack, for your reply.
May I request you to elaborate a little more on this subject.
Thanks,
RAJESWARI.
06/30/2011 2:22 PM
Depending on the system it also is sized to give you max dry steam output and drop out any residual water droplets.
Rich Hurd
Good Answers: 67
07/09/2011 2:41 AM
"What are the deciding Criterion for the Boiler Drum Capacity for different Pressures and Capacities of a Steam Boiler.? Is it linked to Percentage of Capacity or Time or Pressure.?"
Rajeswari, in your post I think you mean "boiler drum size" and not the capacity. In fact you have answered your own question. The boiler drum size depend on two parameters- capacity and pressure, bigger for more capacity and smaller for more pressure (because Sp. Vol. of Steam comes down). Boiler drum is nothing but a big pipe collecting steam from all small pipes and having arrangements for draining condensate. Piping velocity is a factor for its sizing, which depend on those two parameters- capacity and pressure.
07/09/2011 4:53 AM
Dear Mr.Pritam,
Thank you for your reply. My point is what is the deciding criterion for the drum size which is holding wet/dry steam - Is it one minute capacity or 2 minutes or 15 minutes capacity.
Normally the drum size is in the order of 1600 MM dia for pressure upto 110 bar. Suppose we decide for 1 hour capacity the drum size will be large.
I have come across several Boiler Manufaacturers Engineers who are in design side, they also not clear and reply we simply follow the earlier records.
Thanks.
Rajeswari.
Good Answers: 67
07/09/2011 8:51 AM
Rajeswari, basically the limiting velocity should be the criteria for design, which depends on boiler capacity in (tones/hour) and pressure. I'm not a boiler specialist, but you can interpret it in terms of "minutes of capacity" also ones you know diameter and length of boiler drum. Just refer www.federalcorp.com/tech/stempres.htm and www.brighthub.com/engineering/mechanical
07/09/2011 10:52 AM
Thank you Mr. Pritam, for your reply and study the link you have provided.
Any doubt I will post it in this Forum.
RAJESWARI
Register to Reply 7 comments
pritam (2); PWSlack (1); rajeswari (3); RLHurd (1)
