Previous in Forum: Brush/Brushless Synchronous Motor?   Next in Forum: UPS Neutral and Utility Neutral
Insulation Resistance Test For Wye Connected Generator
06/29/2011 10:18 PM
Hi all,
I have currently a 4 wire, 6 leads - 3 phase wye connected generator and i am intending to perform insulation resistance test on the generator.
I manage to get the IR test readings for Phase1/2/3 - Ground.
However , for the insulation resistance test between the phases ( i.e Phase 1 - 2 , phase 1 - 3 etc ). I am constantly getting 0 ohmn.
What could be the problem causing this?
Btw, I have already removed the neutral point of the generator
Can any kind souls advise please?
Urgent ! As i am doing th eload test soon !
There is no limit towards how much one can learn.
Re: Insulation Resistance Test For Wye Connected Generator
06/29/2011 11:34 PM
Ahem. I presume that you get zero ohms with a megger because you were just testing for insulation resistance. If you look at a Wye wiring diagram, you should easily see why you have a low resistance between phases.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
06/30/2011 3:21 AM
I am agree with redfred,
If you are testing insulation resistance of a star connected generator with the isolated neutral, the insulation tester will never show a reading of 0 Ohm until and unless there is any short-circuit between the phases. I think you have forgot to isolate the neutral.
But if you have isolated the neutral, then remove all connections of all 6 leads and measure insulation resistance between the phases and ground.
Vinu_Answers Sure_Answers
Sure Answers Always
Good Answers: 181
06/30/2011 2:16 PM
"But if you have isolated the neutral, then remove all connections of all 6 leads and measure insulation resistance between the phases and ground"
Our OP has already tested 3 phases to ground and from what I can see got good readings. He does now need to split the star point to test between phases.
06/30/2011 10:44 PM
I assume you have a 3-terminal insulation tester . . . Hi - Lo - Guard.
Also assume that all your 3 phases - with 6 leads are disconnected from ground.
SO, to test between phase A to B, connect A to Hv, . . B to Lo, everything else to Guard and ground it.
07/02/2011 4:14 AM
hi,
greetings from India,
6 leads mean R (r1r2),Y (y1,y2) B (b1,b2)
1. you have tested Ph- Earth and got values( hope those are acceptable as you have not mentioned them (above 20 M ohm))
2. do you have removed N link between r2-y2-b2 ?
if so then you must get good IR between r1 & y1, y1 & b1 and b1 & r1.
if this shows '0' M ohm then there must be inter turn fault (or due to heavy moisture content)
Otherwise check the set for residual voltage by removing excitation.
this must be balanced and equal P-P and P-n wise.
if this test is ok then you may start the set.
aditya01 (1); olehwi (1); redfred (1); TonyS (1); Vinu_Answers (1)
