I have just installed a new AGM battery bank (2 banks of 4x6v 350ah giving 24v at 700ah - Charging rates; Absorption at 29.4v and Float at 27.4 as per the battery suppliers instructions). I am using the Morningstar TriStar MPPT-60 controler.
The settings in the controller have been set to achieve battery supplier charging settings.
The system is running all the time to ensure that the frig/freezer operates.
In the morning, the Trace TM500A battery monitor shows 25.4v (fully charged???) but the diodes on the TriStar show Yellow that indicates that the charge is 35-60%.
Later at 26.4v (charging), the Green/Yellow diodes indicate 60-80% SOC.
Can anyone advise me as to whether the stable voltage of an AGM lead acid cell is higher than a flooded cell, and if so, what it is?
