Previous in Forum: Welding Procedure of p-91   Next in Forum: Automatic Drill Sharpener
Electrostatic Coated Abrasive Plant
07/04/2011 8:10 AM
How to prevent HT sparking and arcing in an electrostatic coated abrasive plant?
Applied votage : 0-40 kV recitified DC
Gap between electrodes : 20 mm. to 40 mm.
Web speed : Upto 30 m/min.
Re: circon
07/04/2011 8:16 AM
What is the web material?
Re: circon
07/06/2011 7:30 AM
Web material is conductive glued cloth
Good Answers: 181
Re: Electrostatic Coated Abrasive Plant
07/14/2011 7:53 AM
The electrode current is the key with electrostatic transfer, the current determines the transfer rate. The voltage should control the current. The speed of the web controls the coating thickness, so it's a case of balancing the two.
Is this a case of trying to increases output?
circon (1); PWSlack (1); TonyS (1)
