Previous in Forum: Electrostatic Coated Abrasive Plant   Next in Forum: Tool Steel
10 comments
Automatic Drill Sharpener
07/05/2011 3:21 AM
Hi,
can anybody recommend which brand or company is good to buy automatic drill sharpener machine??? (not manual i need)
Re: Automatic drill sharpener
07/05/2011 3:24 AM
07/05/2011 3:27 AM
it is not automatic.
07/05/2011 3:55 AM
Okay, then $ x 10 (or worse). Or just sharpen them by hand, if you know how. (My own vision is now getting a bit imprecise for this, hence the recommendation.) It is a bit of an art form, which tends to work best for those who actually are into art forms. Or would this be lost art forms?
07/05/2011 4:47 AM
i couldn't understand what you are trying to say... sorry
Good Answers: 18
07/05/2011 4:44 AM
Hi castkarthick,
It would be most helpful if maximum and minimum diameter of the drills to be sharpened was known and what part of the world you are in as the freight charges could be more than the machine.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
07/05/2011 4:48 AM
i need to grind 9.5mm and 1/2". i am from singapore.
07/05/2011 4:48 AM
.........and indeed what type of drill. Are these fluted twist drills, core drills, tapered reamers, spade-type wood bits, corkscrew bits, screw-diggers, or what?
07/05/2011 4:52 AM
parallel shank fluted twist drills.
Good Answers: 181
Re: Automatic Drill Sharpener
07/14/2011 7:38 AM
Just look on Google.
07/17/2011 11:23 PM
You can check out RUSH Machinery, www.rushmachinery.com
Good luck - Bill Herbst
Global Superabrasives
www.globalsuperabrasives.com
Register to Reply 10 comments
billherbst (1); castkarthick (4); jesw55 (1); PWSlack (1); TonyS (1); Tornado (2)
You might be interested in: Guide Bushings and Drill Bushings, Drill Bits, Drills
