Previous in Forum: Hydrualic Test Bench   Next in Forum: Selection Between Forward Curve & Backward Curve in Line Fans
Stress Bend
07/04/2011 3:54 PM
Dear Colligues,
this issue is faced today when we were replacing leaky portion of flow line in 4 inch dia flow line and adding pup piece almost 20 feet
when we place this pup piece between both ends of flow line, it was a much difference in their exact axis( both were not in same plane) Pic is attached
so we pulled the existing length with crane and forcelly matched the joint fit and welded
but after welding when joint was left free after welding, a bend due to stresses produced
plz tell me its acceptance criteria and discuss about situation
regards
Nauman
Jam Nauman +92 334 31 54 181
Re: stress bend
07/04/2011 4:33 PM
"so we pulled the existing length with crane and forcelly matched the joint fit and welded"
Is this is an accepted BP practice?
Re: stress bend
07/07/2011 1:16 PM
lyn
no it is not an acceptable practice in BP
but we are working on this issue , how to resolve it
when a joint forcely matches for welding ,and observe a distortion from its actual path what would be the acceptance critera to reject such practise
plz
guide me if u can
Re: stress bend
07/07/2011 1:34 PM
"no it is not an acceptable practice in BP"
What IS the accepted practice?
"how to resolve it"
Simply put, don't "forcefully" insert a replacement section.
"what would be the acceptance critera to reject"
Ideally, your company should provide the criteria, which would be based on standards established by an appropriate engineering organization. For example, we have the American Society of Mechanical Engineers (ASME) and the American Welding Society (www.aws.org).
Good Answers: 141
Re: stress bend
07/04/2011 7:03 PM
A nice bend is also beautiful. As the picture shows, I see no way to do it straight on, since both ends do not seem to be in line.
Plenty of room here
Re: stress bend
07/05/2011 6:47 AM
As the photograph suggests, the lack of alignment appears due to bend in pipe route. It would be better to cut main pipe on both ends, instal straight lengths from both ends with a pipe bend in between where lengths meet. I am only estimating the solution with a conventional water piping system layout
Good Answers: 88
Re: Stress Bend
07/05/2011 9:14 PM
This gives me a clue why it leaked in the first place. And if you don't remedy the cause it propably will again. What's the fluid-soil temp differences range? S.M.
Good Answers: 67
Re: Stress Bend
07/13/2011 6:17 AM
Pulling and adjusting the axis is a normal practice in piping up to some extent, but effort should be to make it stress free as far as possible. Here, after welding pipe got bent means stress is too high. Better to redo the job.
Register to Reply 7 comments
Anonymous Poster (1); dvmdsc (1); Geon Melek Zahir Ahsan (1); lyn (1); pantaz (1); pritam (1); SimpleMind (1)
