Previous in Forum: Stress Bend   Next in Forum: Heat Exchanger Design
Selection Between Forward Curve & Backward Curve in Line Fans
07/04/2011 11:07 PM
Please suggest the choice or selection criteria suitable for exhaust sytem for between forward curve & backward curve in line fans
Re: Selection between forward curve & backward curve in line fans
07/04/2011 11:21 PM
If dust or other sticky stuff is present, radial vanes will shed it the best. If actual conditions differ from design estimates, forward curved vanes can overload the motor. This is less of a concern with backward curved vanes, but I think they are less efficient than a well matched forward curve selection. (It has been a while since I consulted a fan book, so other input may be better.) Some fan catalogs feature an engineering section that may give good guidelines.
Good Answers: 67
Re: Selection Between Forward Curve & Backward Curve in Line Fans
07/17/2011 5:54 AM
Only backward curved fans are preferable unless high pressure rise is needed. Also efficiency of backward curved fans are better. you should give more details like flow rate, temp, pressure etc. for better comments.
Register to Reply 2 comments
