Previous in Forum: Selection Between Forward Curve & Backward Curve in Line Fans   Next in Forum: Powerless Canon Carrier
Heat Exchanger Design
07/05/2011 12:21 AM
Hi, all of intelligent people
Could you please describe to me pertaining to design facts for Heat exchanger? Additionally, when we are designing the heat exchangers, as a designers, absolutely what shall be considered?
Meanwhile, what is main facts that influences mechanical design? Specially, what does relative facts influence on designing a heat exchanger? It would be really beneficial experienced people advise me so as to let me better understand. Also, overall concept to design the heat exchanger would be helpful.
Thank you so much all. Good luck.
Re: Heat exchanger design
07/05/2011 12:30 AM
Area, area, and area--for starters.
07/05/2011 12:33 AM
Pressure containment and pressure containment, for two more....
Good Answers: 181
07/05/2011 4:35 AM
"as a designers, absolutely what shall be considered"
Our fee for doing your work!
Good Answers: 34
07/05/2011 5:29 AM
Please review TEMA Chapter 6. Get there important vibration considerations.
07/05/2011 5:43 AM
  • Log-mean temperature difference
  • Pressure drop for each fluid
  • Piping connections
  • Size and mounting
  • Weight
  • Material compatibility with the fluids
  • Containment vessel pressure rating
  • Fouling and cleaning
  • Etc., etc.
Good Answers: 19
07/05/2011 7:30 AM
"When we are designing the heat exchangers, as designers " How can you call yourself designers when you are yourself asking us facts on how to design heat exchangers.
What type of heat exchangers are you planning to design? Plate/Tubular/Spiral ? What media you wish to use on? flow? temperature?gpm?
"absolutely what shall we consider" - I'd suggest you read a couple of books on heat exchangers, get in touch with leading heat exchanger manufacturers, get their brouchers , study them then decide if it is wise enough to get into this designing business.
Register to Reply 6 comments
Anonymous Poster (1); ducon (1); PWSlack (1); TonyS (1); Tornado (1); Whitephone (1)
